Vegas Pro 12 Issues
COW Forums : VEGAS Pro
Aaron Lohn
Vegas Pro 12 Issues
on Sep 20, 2014 at 10:36:30 pm
Hello, I am making a video that uses footage recorded with an iPhone as well as normal sized videos recorded on the PC with FRAPS. When I edit pictures and other thinks into the video, it fits perfectly fine in the preview screen and there are no problems. However, when I render it, the pictures are all in random places and not where i placed them. An important thing to note is that the preview window is in the size for the iPhone while the rendered is in the size of the FRAPS recordings. Anyone that knows how to fix this would be saving my life! Thanks a ton!
Steve Rhoden
Re: Vegas Pro 12 Issues
on Sep 21, 2014 at 12:26:35 am
Don't know what to advise you on, FRAPS is always a problematic
video source to edit and render properly.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
John Rofrano
on Sep 21, 2014 at 12:58:29 pm
[Aaron Lohn] "An important thing to note is that the preview window is in the size for the iPhone while the rendered is in the size of the FRAPS recordings."
If you are working with two different size videos, I would set your project resolution to match the size of your delivery format. That will force you to crop everything so that it looks like it should in the final format.
As Steve points out, FRAPS has historically had problems when rendering with Vegas Pro but lets make sure the problem isn't be caused by improperly setting up your project first.
~jr
http://www.johnrofrano.com
http://www.vasst.com
