Creating a PNG in Vegas leaves a dark edge when compositing in Photoshop
COW Forums : VEGAS Pro
Michael Gyiu
on Sep 18, 2014 at 7:54:31 am
Creating a PNG image in Sony Vegas Pro leaves a dark edge when
compositing in Photoshop. Any way to prevent this?
Sony Vegas generated PNG (dark edge)
http://s27.postimg.org/3n3i3mnc3/eye_png_vegas_Composit.jpg
Photoshop generated PNG (perfect)
http://s17.postimg.org/6yxjg3ljj/eye_png_photoshop_Composit.jpg
files:
http://s13.postimg.org/5x3amyvon/eye_png_photoshop.png
http://s2.postimg.org/4ifr6s86x/eye_png_vegas.png
http://s29.postimg.org/m4dy0yxcn/image_jpg.jpg
Graham Bernard
Re: Creating a PNG in Vegas leaves a dark edge when compositing in Photoshop
on Sep 18, 2014 at 11:55:40 am
It would appear you've got a NON-transparent "feather" edge. I'd be going back to PS to determine a better way to graduate the edge through to transparency. I don't see this as a Vegas issue.
Grazie
Michael Gyiu
on Sep 18, 2014 at 2:09:17 pm
Why would a feather-edge be non-transparent? - the whole point of it is to create transparency! This is a BIG issue - It needs a proper solution or It's goodbye Vegas!
Graham Bernard
on Sep 18, 2014 at 3:30:37 pm
How did you create, and save the feather result? Where in VP did you create the Feathering?
G
Michael Gyiu
on Sep 18, 2014 at 5:35:54 pm
I make mask in event pan/crop and add feather, is their another way?
To get PNG i render PNG image sequence or save snapshot to file
Graham Bernard
on Sep 18, 2014 at 6:28:23 pm
Right click on the Event and open the Properties. Navigate to the ALPHA settings. You need to select Premultiplied OR Premultiplied (Dirty).
My guess you still have "Straight (unmatted)"?
Any good?
Grazie
Michael Gyiu
on Sep 19, 2014 at 10:36:04 am
Did you actually test this and get it working?
if so - what was the process you followed (step by step)
I tried everything I could think of and the results are the same
what did you do that I didn't???!!!
Graham Bernard
on Sep 19, 2014 at 2:44:56 pm
[Michael Gyiu] "Did you actually test this and get it working?"
Yes, yes I did:-
DARK RING:
NO DARK RING:
Michael Gyiu
on Sep 19, 2014 at 4:15:06 pm
From the images it looks like you didn't export a PNG???
If you did export successfully what was your process?
Like I said - the problem is with PNG's! - I have no dark rings inside Vegas.
Graham Bernard
on Sep 19, 2014 at 4:31:41 pm
Here's a big clue that I did: The captures have an ALPHA component. I did this from WITHIN Vegas. You can tell this from the Transparent background.
I'm truly interested to hear why you say I DIDN'T?
Grazie
Michael Gyiu
on Sep 19, 2014 at 6:25:36 pm
I saw the console & assumed you hadn't (this issue is clearly effecting my brain function!).
Focusing back on the issue... i changed the Alpha Channel like you suggested but this makes no difference... so whats the process to achieve this?
Graham Bernard
on Sep 19, 2014 at 7:35:55 pm
My process:
1] Seagull Event on Timeline.
2] Use PanCrop Mask to create that selected Oval.
3] Applied Feather to Mask.
4] Saved PNG of seagull.
5] Place PNG back onto Timeline over the Background.
6] Right Click on 5] above.
7] Apply the Premultiplied switch and the DARK RING goes away.
That's it!
Grazie
Michael Gyiu
on Sep 19, 2014 at 11:12:57 pm
I tried this and it works!.. what I was doing was applying premultiplied before exporting it as PNG.
Thanks allot for your help in fixing part of the problem..
Now I need to figure out how to save the PNG premultiplied so i can use it in other software besides Vegas.
If anyone knows how please let me know!
