Sony Vegas Pro 9.0 - Problem: Unmanaged Exception (0xc0000005)
COW Forums : VEGAS Pro
Sadaf Iqbal
on Sep 13, 2014 at 6:51:10 pm
Hi there,
I am wondering if anyone can offer any help with an error I am experiencing with Sony Vegas Pro 9.0. SV has been closing down with a 'problem report' (listed further below) when I try to import a video file or picture. Some are avi but most are in mp4 format and I have the K-lite standard codecs installed and ffdshow audio and video decoder. I have uninstalled quicktime but that's not worked. I have been using this version for the last 3 years and will be upgrading soon but need to complete some projects in 9.0 first.
specs:
(3 year old machine that has recently been updated with a new graphics card)
OS: Windows 7 Home Premium 64 Bit
Processor (CPU) Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache)
Motherboard ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
Memory (RAM) 16GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (4 X 4GB)
Graphics Card 2GB NVIDIA GEFORCE GTX 660 - 2 x DVI, HDMI, - 3D Vision Ready
1st Hard Disk 120GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 130MB/sW)
2nd Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Problem report:
Problem Description
Application Name: Vegas Pro
Application Version: Version 9.0 (Build 562) 64-bit
Fault Module: C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll
Fault Address: 0x000007FEFC2FBAD1
Fault Offset: 0x000000000003BAD1
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
Process Version: Version 9.0 (Build 562) 64-bit
Process Description: Vegas Pro
Process Image Date: 2009-04-17 (Fri Apr 17) 17:08:50
~S
Graham Bernard
Re: Sony Vegas Pro 9.0 - Problem: Unmanaged Exception (0xc0000005)
on Sep 13, 2014 at 8:49:08 pm
Some immediate potential issues that leap out are:
1] K-Lite CODEC Pack? When did you install that?
2] Your VP9 is Build 562. The very last Builds were either 1147 or 1146.
3] How much space are you running on?
4] You say that you have issues with MP4. This means absolutely nothing if you don't also say WHAT is inside it? Same for the AVI.
Get some info back here about my 4] above.
Grazie
Sadaf Iqbal
on Sep 13, 2014 at 9:09:00 pm
Hey, thanks for responding.
1] K-Lite CODEC Pack was installed on January 2013 and then appears to have a new folder version 31st August 2014
2] Your VP9 is Build 562. The very last Builds were either 1147 or 1146. Should I try VP9.0e? Will my configurations files still be viewable on this newer build?
3] 2TB on C-drive with 1TB still free and 1TB internal storage (again, half is free) and another 1TB external drive.
4] I usually experience issues with AVI and MKV music video or movie/show videos in SV so I convert them in to MP4 before editing them in SV.
Dave Osbun
on Sep 14, 2014 at 12:53:26 am
That error message (comctl32.DLL) is a Microsoft Visual Basic control used for creating the item boxes. The software is crashing while opening because it can't create the boxes used for listing or grouping items. Something in your system corrupted it. Best bet is to uninstall and reinstall Vegas Pro (download the latest version first). And don't install any of those codec packs as their not needed.
Dave
