BCC 9 Extruded EPS = black screen
COW Forums : VEGAS Pro
Frank Stevn
on Sep 10, 2014 at 2:47:41 pm
I use BCC9 in Vegas Pro 13.
I add Extruded EPS fx to an empty event and select the AI file. Then I only get a black screen with a white text showing the path to the selected ai file.
Any idea?
Steve Rhoden
Re: BCC 9 Extruded EPS = black screen
on Sep 10, 2014 at 4:26:27 pm
Check your OpenGl and GPU settings....
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Frank Stevn
on Sep 10, 2014 at 9:41:40 pm
Thank you Steve.
My PC has two display adapters, both AMD Radeon HD 5700 Series.
It makes no difference if I change 'GPU acceleration of video processing' to -None- or -Advanced Micro devices, Inc-, in 'Preferences/Video'; either way I still get the black screen.
Is there a different place to change the OpenGl and GPU settings?
John Rofrano
on Sep 12, 2014 at 11:31:52 am
It could be a problem with the AI file. It must be saved in Illustrator 8 format. Nothing newer will work! Post it here so we can take a look if you already saved it as an Illustrator 8 file and want us to check it out.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Frank Stevn
on Sep 12, 2014 at 1:08:04 pm
Thanks John.
I am working with AI CS9. Fallowing your advice I saved the file as AI8 (*.ai and *.eps) and still doesn't work
7981_test.ai.zip
7982_test.eps.zip
