5D3 clips have fade transitions where there are none.
COW Forums : VEGAS Pro
Colin Andronis
on Sep 10, 2014 at 11:10:05 am
I only get this problem with Canon 5D3 clips.
I have edited clips with no transitions, just cuts.
When I render it out, on about 20% of clips I can see like a 1 or 2 frame fade transition.
Driving me nuts.
Any suggestions?
Thanks.
Norman Black
Re: 5D3 clips have fade transitions where there are none.
on Sep 10, 2014 at 3:07:11 pm
Zoom in on a problem spot in question. You will probably see an overlap of the events of that frame or two you speak of.
If you don't have snapping turned on, this happens easily as it is hard to perfectly align one edge with another. Even with snapping on, one can twitch the mouse a little and get this. Rare but it can happen.
Mike Kujbida
on Sep 10, 2014 at 3:11:38 pm
To add to Norman's post, make sure that Quantize to Frames is enabled as having this turned off can mess you up.
