Jerky Frame dropping when pan and tilt
COW Forums : VEGAS Pro
Matt Cook
on Sep 5, 2014 at 9:53:43 am
Hi All
Im needing a little help and I will try to explain myself as best I can.
So I have several bits of footage from a wedding that get choppy/jerky when ever I move the camera significantly, for instance when tilting slowly up the wedding cake and also when zooming in on a jpeg. its like its skipping a frame and makes everything look jerky.
I can see it in vegas but at the time thought it was just the preview lagging a little, but it has also come out in the render. I tried moveing the original copy from my old drive to my system ssd drive but this didnt help.
The footage is AVCHD 1080/25p
system spec is
i1-4770K @3.5ghz
16 gb ram
Radion 6850 hd
Any ideas guys
Matt
Bob Peterson
Re: Jerky Frame dropping when pan and tilt
on Sep 5, 2014 at 3:54:13 pm
Some cameras do not perform well when doing things like panning. Try panning verrryy slowly and see if that reduces the problem.
Dave Osbun
on Sep 5, 2014 at 5:00:20 pm
Is your camera's sensor a CMOS sensor? Except for the expensive cameras you usually have to pan slowly with modern lower-end CMOS equipped cameras. On my sub-$2000 Sony AVCHD camera I obtain below-quality video on fast moving subjects or quick pans.
Dave
