Importing .MOV
COW Forums : VEGAS Pro
Alexandre Esteves
Importing .MOV
on Aug 14, 2014 at 1:11:22 pm
When I try to import .MOV (H264) to Vegas 11 I get the error "none of the files dropped on vegas pro could be opened". In the last time I had this problem, I just had to install QuickTime, but now I'm stuck (is the same camera that I recorded the videos). I have already installed many plugins, but don't work. =/
Thanks, and sorry for any English errors. I'm Brazilian.
John Rofrano
Re: Importing .MOV
on Aug 14, 2014 at 4:12:04 pm
Do the files open in the QuickTime Player?
What version of Vegas Pro are you using?
What version of QuickTime is installed?
Not all versions of QuickTime work with all versions of Vegas Pro.
One thing you can try is to rename one of them them from .mov to .mp4 and see if that helps. (it may not but it's worth a try)
~jr
http://www.johnrofrano.com
http://www.vasst.com
Alexandre Esteves
Re: Importing .MOV
on Aug 14, 2014 at 10:08:05 pm
Yes, it open.
Vegas Pro 11.0 (Build 682)
QuickTime 7.7.5 (but i tried the 7.6.2 version too)
Hmm.. I'll try others QuickTime versions.
I already tried this. XD
Thanks for reply, John.
Alexandre Esteves
Re: Importing .MOV
on Aug 14, 2014 at 10:51:32 pm
Ok. I have the same Vegas working on my notebook, it import this MOV files normally. The Notebook have the QuickTime 7.7.4, so I installed it here in my Desktop and the problem is the same. "none of the files dropped on vegas pro could be opened"
So I think is not a problem with QuickTime. =/
John Rofrano
Re: Importing .MOV
on Aug 15, 2014 at 12:09:51 am
[Alexandre Esteves] "I have the same Vegas working on my notebook, it import this MOV files normally. The Notebook have the QuickTime 7.7.4, so I installed it here in my Desktop and the problem is the same. "none of the files dropped on vegas pro could be opened""
Wow, that's even worse. Something about our desktop is causing this not to work since your laptop works with the exact same software levels and files.
I wish I know what to tell you (other than rebuild your desktop OS) :( Try re-install Vegas Pro? (just a guess)
~jr
Alexandre Esteves
Re: Importing .MOV
on Aug 15, 2014 at 12:06:32 am
SOLVED
I copied the "Sony" and "QuickTime" folders of the my Notebook's Program Files folder to my Desktop's Program Files, replacing the old folders.
This was really confused.
Thanks, John.
John Rofrano
Re: Importing .MOV
on Aug 15, 2014 at 12:17:59 am
Wow, glad you got it working. That was an odd one.
~jr
