will my setup work with vegas pro 13
COW Forums : VEGAS Pro
jeff rinland
on Aug 12, 2014 at 6:21:59 pm
I am considering buying a Canon G20 and Vegas Pro 13 I'm not sure if my laptop will work though. It meets all requires but it does not have a firewire port, can I just use the usb to import video into vegas pro or no? My video card is a Nvidia GTX 780M I believe that will be fine for vegas pro?
Sorry for the beginner question but any assistance would be appreciated
Steve Rhoden
Re: will my setup work with vegas pro 13
on Aug 12, 2014 at 10:57:47 pm
You dont need firewire ports for that camcorder, you simply connect
it to your computer and drag your videos from it to your laptop or
you use memory cards and acquire the content from those. Then you start
editing with vegas after they are transferred to your laptop.
You will be quite ok!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
David Norman
on Aug 13, 2014 at 4:09:30 am
the CPU is the most relevant information on render times and previewing the video in editing
Dell XPS 15" 9350 i7, 512gb SSD, Nvidia 750m
Intel i7 3930K, R9 290, 32gb, 2xRAID0 Intel 240gb SSD, 2x2TB WD Green, 3x23" Samsung LCDs
http://youtube.com/adidas4275
jeff rinland
on Aug 13, 2014 at 4:32:55 am
CPU is an i7 4910MQ
Dave Osbun
on Aug 13, 2014 at 12:57:22 pm
That CPU will work fine.
David Norman
on Aug 14, 2014 at 4:16:51 am
i have a i7-4702HQ in my notebook and i had a 3770k in my desktop and both run normal 1080p 60fps content fine. they both struggle when adding a lot of effects or keyframing, slow motion stuff...
you wont have any problems doing 99% of editing and depending on what you use for titling and such it might make use of your GPU
John Rofrano
on Aug 13, 2014 at 11:54:39 pm
[Steve Rhoden] "you simply connect it to your computer and drag your videos from it to your laptop or you use memory cards and acquire the content from those."
Actually, you should use the Device Explorer to transfer files so that any video that is split across files due to the FAT32 file limitations of memory cards can be stitched back together correctly.
I would also recommend backing up the entire card structure and not just the video files. This will ensure that you don't loose any metadata needed to stitch files back together in the future.
~jr
http://www.johnrofrano.com
http://www.vasst.com
