replacing media causes media to go offline or generate an error (stabilizing with SA Mercalli)
COW Forums : VEGAS Pro
Jason Merrill
on Aug 9, 2014 at 7:28:27 pm
Hello,
I had edited some clips in Vegas and LATER wanted to stabilize with Mercalli...
I stabilized it, and then I tried to rename the files so that vegas would just pick it up.. and it didnt.
Then, instead of that approach, I tried to use "replace" in "project media" to replace the stabilized media - and it still gives an error.
whats the deal?
Graham Bernard
Re: replacing media causes media to go offline or generate an error (stabilizing with SA Mercalli)
on Aug 10, 2014 at 3:30:17 am
I've learnt that Mercalli doesn't make a file that I CAN do anything with, I get the warning I need to re-apply the Mercalli process. I need to make a RENDERED-out file to allow me to re-edit.
My observation is that Mercalli "holds" our stabilizations results UNTIL rendering. Yes? I find the Mercalli workflow very comfortable. I've never thought of renaming a file until I've rendered-out. I have to ask: Why would you want to rename? I'm sure there's a good reason, I'd like to hear.
Bottom line: Stabilized Events remain volatile, until rendered.
Grazie
Jason Merrill
on Aug 10, 2014 at 4:40:05 pm
I am talking about using the standalone mercalli 3...
Graham Bernard
on Aug 10, 2014 at 4:45:33 pm
Ah, so what format are you selecting to render to in SA V3?
Grazie
Jason Merrill
on Aug 10, 2014 at 4:50:06 pm
mov, which is the original. Maybe I should try mp4.
Graham Bernard
on Aug 10, 2014 at 4:55:41 pm
Well MOV is a QT format. You could try ensuring you have the latest QuickTime Reader installed? So, it may very well be a QT issue and not primarily Vegas - yeah?
Personally, from SA Merc 3, I've ONLY used the MP4 format. Be prepared for the colour space to be squished importing into Vegas, and you'd need to apply a Levels filter too.
Grazie
Graham Bernard
on Aug 10, 2014 at 5:07:04 pm
Jason, I just tried the QT render option, it is very juddery back in VP13. MP4 files are excellent! - And no issue renaming within VP13.
Grazie
Jason Merrill
on Aug 10, 2014 at 5:11:09 pm
thank you for all of this. I will try that and get back to you if it doesn't work out.
your help is invaluable, I shoulda thought of this first ;)
Graham Bernard
on Aug 10, 2014 at 5:22:28 pm
[Jason Merrill] " I shoulda thought of this first ;)"
Yeah, after 15 years at this stuff, I should have your statement etched on my bathroom mirror - so I can read it every morning . . . !
Anyways, you're welcome!
Grazie
Jason Merrill
on Aug 11, 2014 at 6:00:33 pm
it worked! thanks!
