Sony Vegas color ghosting
COW Forums : VEGAS Pro
Rudolph Davis Strazds
on Aug 5, 2014 at 3:42:10 pm
I was recording my screen, everything looks OK on the original footage but when I imported video in sony vegas, colors are just kinda messed up in some parts, tried to render to .mp4, .wav, nothing changed.
What should I do to fix this ?
I already changed colors from 8 bit to 32 bit, disabled resampling, interlacing method, nothing changed.
Original footage ---------------------------------------------------------------- Imported in Sony Vegas 13
Steve Rhoden
Re: Sony Vegas color ghosting
on Aug 5, 2014 at 6:47:36 pm
What screen recording software are you using? and Have you tried
recording your screen in another format?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Rudolph Davis
on Aug 21, 2014 at 12:07:11 pm
I used bandicam, but I don't think that's the problem for this, maybe Sony Vegas can't handle certain video codecs.. Because in original footage played in Media Player Classic everything looks OK.
Here's some info on the original footage
Format/Info : Audio Video Interleave
File size : 139 MiB
Duration : 5mn 22s
Overall bit rate : 3 613 Kbps
Writing application : BandiAviMuxer 1.0
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 5mn 22s
Bit rate : 3 603 Kbps
Width : 1 360 pixels
Height : 736 pixels
Display aspect ratio : 1.85:1
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.072
Stream size : 138 MiB (100%)
Rudolph Davis
on Aug 5, 2014 at 9:33:27 pm
bump
Rudolph Davis
on Aug 20, 2014 at 6:37:33 pm
bump
