Loaded Video becomes Choppy and Green
COW Forums : VEGAS Pro
Don Parsons
on Jul 31, 2014 at 3:43:03 am
I noticed this was a common problem. I have Sony Vegas 13 64bit
I was searching through the forums trying to find an answer for my predicament but couldn't come to a conclusion. I tried a few of the given answers but they didn't Work. My gpu acceleration is off and I tried re-installing. I looked through the settings for something, but to no avail. I read that it would sometimes be corrupt files, but the problem is I'm using files that I've already used multiple times and now they're just not loading correctly. I find that the files over a certain size or amount of time just started setting it off.
All suggestions and solutions accepted. Thanks in advance.
EDIT: I have realized the frame rate is incorrectly loaded. Don't know why. Today is the first time I've had this problem and I haven't installed any Codec files or anything new like that.
EDIT2: Has nothing to do with duration. A 41 minute file has an FPS of 1 while a 46 minutes and another of 38 minutes has a FPS of 60.
EDIT3: They load and run fine in Wondershare Video Editor
John Rofrano
Re: Loaded Video becomes Choppy and Green
on Jul 31, 2014 at 11:12:47 am
What codec does the video use? Where did it come from? Usually green video is codec related.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Don Parsons
on Jul 31, 2014 at 4:12:42 pm
It's an H.264 Mp4 codec. I made the video using HD PVR 2 and captured with Arcsoft. It's 3 files that suddenly stopped working with Vegas 13. They still work with other editing software though.
EDIT: Just recorded a new video, same way I always do, and it worked fine. Didn't change any setting or tamper, just works fine. Just seems to be those 3 files.
EDIT2: Just ran it in AVI Demux. Runs fine at start then gets the same choppy frame rate. Also says the video is about 41 hours long. It's just under 2 hours.
EDIT3: And looking at the media info with AVI Demux seems to be 100%. Duration, frame rate, everything. But it just says on the front end that the video is 41 hours long with a regular frame rate, or and hour and 51 minutes with a 2.2 frame rate.
John Rofrano
on Aug 1, 2014 at 11:31:36 am
It sounds like something got corrupt with those 3 files. If AxiDemux is having trouble then it's not Movie Studio. Try converting them to M-JPEG and see if that helps:
~jr
Don Parsons
on Aug 1, 2014 at 4:28:03 pm
Alright, tried to convert but it just created a file that's 126 kb. Guess the file is really broken.
John Rofrano
on Aug 2, 2014 at 1:08:22 am
Yea, it sounds like the files got corrupt somehow.
~jr
Don Parsons
on Aug 2, 2014 at 4:20:11 am
Seems that way. Still loads and plays fine. Loaded it up with another program and used that to make the video. Doesn't really look as "Professional" but it does the job.
John Rofrano
on Aug 2, 2014 at 11:31:29 am
[Don Parsons] "Loaded it up with another program and used that to make the video. Doesn't really look as "Professional" but it does the job."
If you can load it with another program why not render it out to a new format in that program and edit in Vegas Pro?
~jr
Don Parsons
on Aug 3, 2014 at 8:50:10 am
Quality loss. The video editor I use has slight quality loss.
