Sony Vegas not importing full Video files (mp4)
COW Forums : VEGAS Pro
Ajay Singh
on Jul 28, 2014 at 4:51:26 pm
Having some problems with importing Video files into sony vegas. When i go to import or drag a video file it changes a 11 minute long video into a 3 minute. This seems to only happen with the mp4 files that i have recorded using Nvidia Shadowplay
as you can see for this one the video after being imported into sony vegas hasn't been changed
This one however gets cut
What is happening and how can we fix this?
Steve Rhoden
Re: Sony Vegas not importing full Video files (mp4)
on Jul 29, 2014 at 11:17:20 am
Your issue is with the mp4 format captured using that Nvidia Shadowplay.
Try capturing it in another format apart from mp4 if it can.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Ajay Singh
on Jul 29, 2014 at 3:35:17 pm
Could you reccomend any other recording programs that I could use? I'm aiming for high quality but also a program that doesn't make me drop 100 fps when I start recording. I have tried fraps and obs both are not satisfying
chris king
on Aug 13, 2014 at 6:09:08 am
I finally find two methods that can solve the problem.
Solution 1: Looking around Google results suggests I need a codec. Install the K Lite Codec Pack is a possible solution.
Note: I also found people blaming the codec saying K-Lite is that it blindly installs all kinds of components (not just codecs), many of which are not compatible with each other. And it does not uninstall cleanly. If don’t want to install a pile of codecs on your PC, try another approach.
Solution 2: There are more than one guys online recommend to convert MP4 to Sony Vegas Pro more edit-friendly video like MPEG-2.
