Fatal Error after apply proDAD Mercalli 2.0
COW Forums : VEGAS Pro
leaning less
on Jul 28, 2014 at 11:58:17 am
I've tryed reinstall plugin (2.115 & 2.117) and program (13.0 build 373), but it disn't help. How should i solve this problem?
Graham Bernard
Re: Fatal Error after apply proDAD Mercalli 2.0
on Jul 29, 2014 at 1:10:37 pm
[leaning less] "I've tryed reinstall plugin (2.115 & 2.117)"
I don't recognize your Mercalli Plugin Version: 2.115 & 2.117 . I read for you what they are. They don't APPEAR to be for VEGAS PRO.
03-Jun-2014 Plugin 2.0.117 79 Plugin for Premiere CC 2014
15-Nov-2013 Plugin 2.0.115 79 Plugin for Corel X7 64bit
Graham Bernard
on Jul 30, 2014 at 6:45:27 am
I've now updated to Build 373 and can confirm that my build of Mercalli works fine with Build 373 of Vegas.
From the information you have supplied, it would appear you've installed a non-VegasPro Mercalli plugin. If this is the case you should consider:
1] Downloading the correct Mercalli plug for VP
2] Uninstall the exsisting Mercalli plugin and reboot system.
3] Confirm the Mercalli plugin is not available within VegasPro and close VegasPro.
4] Install the correct Mercalli plugin and reboot system.
5] Open VegasPro and confirm Mercalli is working.
HTHs
G
