Best process for sequenced film frames to video file?
COW Forums : VEGAS Pro
John Romein
on Jul 25, 2014 at 5:59:16 pm
I'm using Sony Vegas Pro 13 with UltimateS and trying to find the best way to get a set of sequenced film frames into a video file in the highest quality possible. From all the reading I feel the best way is to place the images onto the timeline in a pulldown pattern and to avoid blended frames. I used the import media function (and also tried to just drop the images onto the timeline)... When I used the import media function (selecting the stills option) it displayed a Properties box where i could select the frame rate. Should I used the frame rate of the film (ie. 16fps or 18fps or 24fps) or the final video?
Once I get the right setting for the timeline, I now need to pick out the render options. The output should be the best quality for archival purposes. Suggestions?
Cheers,
John
John Rofrano
Re: Best process for sequenced film frames to video file?
on Jul 26, 2014 at 11:57:54 pm
[John Romein] "Should I used the frame rate of the film (ie. 16fps or 18fps or 24fps) or the final video?"
Select the frame rate of the original film. Vegas needs to know how to reassemble the images into the original video so you want to have it match the original. If, for example, these are images taken at 16 fps then tell Vegas they are 16 fps.
[John Romein] "Once I get the right setting for the timeline, I now need to pick out the render options. The output should be the best quality for archival purposes. Suggestions? "
Sony YUV is archive quality but the files are huge. I would just render them to Sony MXF with one of the HD422 50Mbps templates. That should give you plenty of quality with decent file sizes.
~jr
http://www.johnrofrano.com
http://www.vasst.com
John Romein
on Jul 27, 2014 at 3:22:31 am
Thanks John.
I tried both the Sony YUV and Sony MXF with one of the HD422 50Mbps templates. The issue I found with both is that the results produced ghosting and blended frames. Also the images are all 4:4:4 and I sort- of would like to keep the quality high.
I suspect that I need to do a pulldown sequence to get the frames from 17 to 24 or 29.97 and then apply the recommend renders...is this correct? BTW I did look at your 18to24 conversion script...is this what I need. Or is there a way to force Vegas to do a non-blended pulldown?
Using Vegas Pro 13 and UltimateS.
Cheers,
John
John Rofrano
on Jul 27, 2014 at 12:40:58 pm
[John Romein] "The issue I found with both is that the results produced ghosting and blended frames. "
That has nothing to do with the codecs. That has to do with the difference in frame rates. The only way to convert from one frame rate to another is to either blend the missing frames or duplicate the missing frames. Take your pick.
[John Romein] "Also the images are all 4:4:4 and I sort- of would like to keep the quality high. "
You could render to Avid DNxHD 10-bit 444 or Uncompressed if you want to keep then 4:4:4. You'll probably need a RAID 0 too keep up with the data rate of uncompressed HD.
[John Romein] "I suspect that I need to do a pulldown sequence to get the frames from 17 to 24 or 29.97 and then apply the recommend renders...is this correct?"
Yes, Vegas Pro knows how to pulldown from 24 to 29.97 but it's probably not going to do that well with the 17 fps footage which is why you saw the ghosting.
[John Romein] "BTW I did look at your 18to24 conversion script...is this what I need. Or is there a way to force Vegas to do a non-blended pulldown?"
I'm not sure which script you are referring to. If you want it to duplicate the missing frames you can go into the event properties and turn on Disable Resample and it will duplicate frames instead of blending them.
~jr
John Romein
on Jul 27, 2014 at 8:46:01 pm
Thank you very John.
The script I referred to in the previous post is the following:
http://f1.creativecow.net/7277/convert-18p-to-24p-script-for-vegas-pro
The tip about disabling the resampling did the trick. Now the renders look much better. Now I just need to decide the delivery format, mxf or avi?
Cheers,
John
John Rofrano
on Jul 28, 2014 at 12:09:03 am
[John Romein] "The script I referred to in the previous post is the following"
Wow I totally forgot I wrote that script! lol
[John Romein] "The tip about disabling the resampling did the trick."
Glad that worked for you.
~jr
