Rendering interlaced videos
COW Forums : VEGAS Pro
nmou nmou
on Jul 24, 2014 at 11:13:13 pm
Hi, its been a while since i came here but i have a question :
I have some old dvds that i found and i want to keep them on my pc with h264 codec for a lower size so my question is if i encode them on vegas with mp4 avc bitrate at 760 kbps witg same resolution will i have almost the same quality as original and another question more important, if i check the interlaced "upper field first" option will my videos keep the same interlaced quality of my dvds ?
John Rofrano
Re: Rendering interlaced videos
on Jul 25, 2014 at 12:26:28 am
[nmou nmou] "if i encode them on vegas with mp4 avc bitrate at 760 kbps witg same resolution will i have almost the same quality as original"
Almost but not quite. You can expect about a 5-to-1 reduction in size from MPEG2 to MPEG4 at the same quality. Most DVD's are recorded the an average bit-rate of 6 Mbps and 1/5th of that is 1.2 Mbps so you would need at least 1200 kbps to maintain the same quality. How much less quality 760 kbps yields you'll have to see for yourself.
[nmou nmou] "if i check the interlaced "upper field first" option will my videos keep the same interlaced quality of my dvds ?"
You don't want to do that. The reason DVD's are interlaced is because the TV's you watch them on are interlaced. Your PC monitor, however, is not interlaced so you don't want your MP4 videos to be interlaced. Keep them progressive if you plan to watch them on your PC.
~jr
http://www.johnrofrano.com
http://www.vasst.com
nmou nmou
Re: ndering interlaced videos
on Jul 25, 2014 at 12:32:27 am
But I want to watch them on the TV so how can I keep the interlaced quality ?
John Rofrano
on Jul 25, 2014 at 12:54:13 am
[nmou nmou] "But I want to watch them on the TV so how can I keep the interlaced quality ?"
Oh I see... you play them on your PC but it is connected to your TV. In that case you can select Lower Field First if the are NTSC DVD's and it will maintain the interlacing. Some DVD's may actually be Upper Field first so you might want to check the field order of the source before you decide but most were Lower Field First.
~jr
nmou nmou
on Jul 25, 2014 at 12:58:10 am
My dvd are PAL interlaced upper first i am french so i check "upper field first" but will it keep the originl interlaced process ?
John Rofrano
on Jul 25, 2014 at 1:02:19 am
[nmou nmou] "My dvd are PAL interlaced upper first i am french so i check "upper field first" but will it keep the originl interlaced process ?"
Yes, PAL is Upper and NTSC is Lower. Keep them Upper if they are coming from PAL DVDs.
~jr
nmou nmou
on Jul 25, 2014 at 1:05:33 am
Ok so i will have the same interlaced quality at all ? Thank you
John Rofrano
on Jul 25, 2014 at 10:43:36 am
[nmou nmou] "Ok so i will have the same interlaced quality at all ? "
You should if you bump the bit-rate up to 1200Kbps.
~jr
