Converting AVCHD (.mts) to H.264 => Which are the best container output (.mp4 .mkv .avi .mov) considering further editing in Vegas?
COW Forums : VEGAS Pro
Carlos Silva
on Jul 16, 2014 at 3:40:12 pm
I’ve been recording videos in AVCHD (.mts). Since the files are huge I intend to save storage/space by converting the files to other format/container (keeping the original bitrate and resolution).
I also intend to edit the converted files in Vegas and I would appreciate advice regarding which is the best video container to convert the files and handle them in Vegas. The codec is H.264: mp4 / mkv / mov / avi ?
Ps.: I don't know if this matter, but I am using Movavi Video Converter throughout this process (http://www.movavi.com/videoconverter/).
Carlos
mark thompson
Re: Converting AVCHD (.mts) to H.264 => Which are the best container output (.mp4 .mkv .avi .mov) considering further editing in Vegas?
on Jul 16, 2014 at 4:33:42 pm
Hi
my 2 cents, AVCHD really is H.264 so I wouldn't be expecting very much more compression. You might find a better codec implementation which will compress more than your original but ... Sony already recommend AVCHD as a good editing format. The better format is MPEG2 long gop but that will not benefit from the enhancements in AVC.
Sony published a paper it: http://pro.sony.com/bbsccms/assets/files/micro/xdcam/solutions/MPEG-2_Long_...
mark
Norman Black
on Jul 17, 2014 at 1:28:33 am
[Carlos Silva] "I’ve been recording videos in AVCHD (.mts). Since the files are huge I intend to save storage/space by converting the files to other format/container (keeping the original bitrate and resolution). "
If you keep the same bitrate then the new files will be the same size as the original.
AVC/H.264 is quite editable. It does take more compute power to decode than mpeg-2 for example. As long as your CPU can work with your source files you should be fine.
Jane Kong
on Dec 22, 2014 at 2:53:56 am
I prefer mp4 , this container foramt maybe the most compatible format. And you can load your videos in whatever video editor you like
