Hardware advice - SVP 11
COW Forums : VEGAS Pro
chris evans
on Jul 11, 2014 at 3:15:08 pm
Just finishing another big project, using quite a lot of colour correction with Magic Bullet. I am really starting to notice some slowdown on my system, especially with render times. Still useable, but close to not being so!
Now, I am not a pro by any shot, and don't have a big budget, but feel I need to add a proper GPU to my system.
I currently have a i5 3570k with 8gb RAM and am just using the onboard graphics.
I have read the GTX 570 might be a good card to go for? I can get a second hand one of these pretty cheap.
Will this do the job and be fairly future proof and improve things?
At the moment, I output from the motherboard to two monitors. One through HDMI and one through VGA. Again, not ideal, but does the job for me. Will the new card be ok with this set up?
Thanks.
Steve Rhoden
Re: Hardware advice - SVP 11
on Jul 11, 2014 at 5:07:32 pm
In a nutshell, You are not gonna get any significant improvement doing that.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Dave Osbun
on Jul 11, 2014 at 5:14:03 pm
Even with a modern graphics card, the CPU is still doing most of the work. You will gain a little by upgrading to an Ivy Bridge i7 (and 16gb RAM) but stepping up to the newest Xeon CPUs will yield the best results.
Dave
chris evans
on Jul 11, 2014 at 5:32:10 pm
Ah, ok. So probably not worth it then, without a major upgrade.
Steve Rhoden
on Jul 11, 2014 at 7:22:40 pm
"So probably not worth it then"
No its not worth it!.....
John Rofrano
on Jul 12, 2014 at 11:28:34 am
[chris evans] "I currently have a i5 3570k with 8gb RAM and am just using the onboard graphics."
As others have pointed out, while the Core i5 3570k is a quad core, it doesn't support hyper threading so it only has 4 cores and 4 threads. The Core i7's have 4 cores and 8 threads unless you get a 6 core like mine which has 12 threads. So the Core i5's are OK for light video work but for heaving FX processing you really need to step up to a Core i7 and I would get nothing less than a Hex Core (6-cores) if you are doing heavy color grading.
I'm not so sure that a GPU wouldn't help you out though. I say this because Magic Bullet supports GPU acceleration so a compatible GPU may actually give you some benefit. While GPU acceleration with Vegas Pro has been hit and miss, if you are looking to speed up Magic Bullet, you might want to contact them and see what they say.
~jr
http://www.johnrofrano.com
http://www.vasst.com
chris evans
on Jul 15, 2014 at 11:02:41 pm
Thanks.
I just upgraded to SVP 12 and have been having a play with newbluefx. A lot of the newbluefx effects seems to grind vegas to a halt. It seems to add the effect and if you render they look ok, but it's impossible to preview them, in particular the openfx ones.
Are we saying that a gpu such as a gtx 570 wouldn't help with this? And that if I want to play with the more intense effects I will be needing a CPU upgrade?
David Norman
on Jul 16, 2014 at 5:20:15 am
i am like you, not a pro... just trying to learn and have fun
I have a 3770 i7, 32gb of RAM and a R9 290 in my editing/gaming rig and newbluefx stuff grinds me to a halt without prerending to ram (where 32gb of ram comes in handy)
I am upgrading to a second hand 3930k (6 core, 12 thread) CPU+Motherboard for $500... selling me 3770+motherboard for around $250 and that is a nice upgrade for editing for $250 :)
in short.... with Vegas and most video editors... CPU horsepower is needed
Dell XPS 15" 9350 i7, 512gb SSD, Nvidia 750m
Intel i7 4770, R9 290, 32gb, 2xRAID0 Intel 240gb SSD, 2x2TB WD Green, 3x23" Samsung LCDs
http://youtube.com/adidas4275
John Rofrano
on Jul 17, 2014 at 12:55:45 am
[David Norman] "I have a 3770 i7, 32gb of RAM and a R9 290 in my editing/gaming rig and newbluefx stuff grinds me to a halt without prerending to ram (where 32gb of ram comes in handy)"
The question is what is NewBluFX using to add GPU acceleration? If they only support NVIDIA's CUDA, then your AMD R9 290 is not helping because it only supports OpenCL.
~jr
David Norman
on Jul 21, 2014 at 8:23:46 am
looks to me they support OpenCL.... and AMD cards are on their supported list... though they do not go into much detail on particular cards
John Rofrano
on Jul 21, 2014 at 12:08:56 pm
[David Norman] "looks to me they support OpenCL.... and AMD cards are on their supported list... though they do not go into much detail on particular cards"
That's great news. So the AMD card should be fine then.
~jr
John Rofrano
on Jul 17, 2014 at 12:52:50 am
[chris evans] "Are we saying that a gpu such as a gtx 570 wouldn't help with this?"
I'm saying that it actually might help it. I would contact NewBlueFX. Plug-ins that support GPU acceleration will benefit from having a good GPU.
~jr
chris evans
on Jul 17, 2014 at 6:58:43 am
Thanks John. Will do.
chris evans
on Jul 17, 2014 at 10:43:35 pm
I have been looking at CPU upgrades and I can fairly cheaply change to an i7 3770k.
Will I see vast improvements if I did this?
John Rofrano
on Jul 18, 2014 at 3:49:42 am
[chris evans] "I have been looking at CPU upgrades and I can fairly cheaply change to an i7 3770k. Will I see vast improvements if I did this?"
Overall you should see an improvement but you said you were specifically looking to speed up Magic Bullet and if they have GPU support, you may get a better boost by adding an appropriate GPU. I would definitely contact Red Giant and ask them what they recommend (more CPU or GPU power to help Magic Bullet)
~jr
