"Render As" Speed - CPU vs GPU
COW Forums : VEGAS Pro
Simon Graham
on Jul 4, 2014 at 2:36:47 pm
Hello, I'm looking to build my first dedicated video editing pc for use with Sony Vegas. My budget is £1200 ($2000). The goal is to render 1080p video clips for upload to YouTube as fast as possible.
Render As Template: MainConcept Internet HD 1080P, 20 Mbps
My Question: How should I spend my budget in terms of CPU vs GPU.
Note: I have based my choices on the threads posted here and this rather helpful table: http://www.hyperactivemusic.com/vegaspro/vegaspro.html
Option 1 (Total - £445)
  • i7 4790k Quad Core @ 4GHz (4.5GHz OC) - £245
  • 2 GTX 580 (SLI) or 2 HD6970 (Crossfire) ~ £200 (used)
Option 2 (Total - £515)
  • i7 4930k Hex Core @ 3.4GHz (4.5GHz OC) - £415
  • 1 GTX 580 or HD6970 ~ £100 (used)
Option 3 (Total - £545)
Use Render As Template: XDCAM EX HQ 1920x1080, 35 Mbps
  • R9 290 - £300 (new)
For Option 3 is there any negatives to using XDCAM EX for upload to YouTube instead of MainConcept as both are .mp4 - is it just the higher bitrate?
What do you guys think, would you suggest something different? Any advice would be greatly appreciated. Thanks.
John Rofrano
Re: "Render As" Speed - CPU vs GPU
on Jul 4, 2014 at 3:27:49 pm
I would definitely go with Option 2 for the Core i7 4930k Hex Core @ 3.4GHz with an ATI Radeon HD 6970. You want as many cores as possible. Quad Cores are ancient history for video editors. I would never consider one. Testing has shown the AMD Radeon's to be better performing cards for Vegas Pro's OpenCL based acceleration.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Simon Graham
on Jul 4, 2014 at 3:50:46 pm
Thanks for the reply John,
I always though CPU power was most important for video editing, however going by this table: http://www.hyperactivemusic.com/vegaspro/vegaspro.html
Only CPU = 10-15fps render
CPU + GPU = 45+fps render
Also any suggestions for MainConcept vs XDCAM EX for YouTube?
John Rofrano
on Jul 4, 2014 at 6:56:47 pm
I'm not saying that having a good GPU isn't important, it is, but overall the more cores will give you better CPU performance for everything else. Sony is recommending a minimum of 8 cores to work with 4K. Buying a 4 core computer today is short sighted. At least with 6 cores you are getting closer to future-proofing your investment. My current Mac Pro has 8 cores and I'm currently looking for one with 12 cores to replace it.
~jr
Simon Graham
on Jul 4, 2014 at 9:06:19 pm
Okay 6 cores it is then, thanks for the advice.
Any opinion on XDCAM EX + R9 290?
Going by that table I linked to earlier it supports GPU acceleration with the advantage of being a much newer card. Though I have never used XDCAM EX, is it comparable to MainConcept apart from higher/fixed bitrate? Video is for YouTube only.
John Rofrano
on Jul 4, 2014 at 10:54:40 pm
[Simon Graham] "Any opinion on XDCAM EX + R9 290?"
I've never tried to use XDCAM EX to upload to YouTube but as long as YouTube accepts it. the quality should be great because XDCAM EX is 35Mbps MPEG-2. I find that my ATI Radeon HD 5870 renders to MainConcept AVC slightly faster than to XDCAM EX but that might be different with a newer card like the R9 290. I don't know.
~jr
Dave Osbun
on Jul 5, 2014 at 2:17:02 am
Have you tried pricing an Intel Xeon processor (and associated motherboard)? Might be able to fit in your budget if you do choose the Radeon card that John recommended.
Dave
Simon Graham
on Jul 7, 2014 at 10:50:31 am
Thanks Dave,
I've had a look into the xeon processors and for my budget it looks like the i7 is the way to go.
Ive ordered all my parts apart from the graphics card: HD 6970 vs R9 290
Does anyone have any experience with XDCAM EX vs MainConcept for upload to YouTube?
Thanks again everyone.
David Norman
on Jul 16, 2014 at 5:39:42 am
for the price the 3930k or the 4930k are the best bang for buck 6 core CPUs .... for video editing we dont need ECC ram and such you get with Xeon line...
$500 for a CPU is nice with 6 cores and if you dare to overclock and test for stability you can get great performance out of the 3930/4930k cores.
I recently made the same choice
Dell XPS 15" 9350 i7, 512gb SSD, Nvidia 750m
Intel i7 4770, R9 290, 32gb, 2xRAID0 Intel 240gb SSD, 2x2TB WD Green, 3x23" Samsung LCDs
http://youtube.com/adidas4275
