Sony Vegas Pro 11 crashes when rendering iPhone (mov) plus Galaxy S4 (mp4) clips in one edit
COW Forums : VEGAS Pro
Benjamin Köpeczi-Bócz
on Jul 1, 2014 at 12:08:07 pm
Hello Guys!
Help me please! When I render the iPhone and Galaxy S4 clips in Vegas it crashes when it reaches 7%. The following message can be seen:
Extra Information
File: C:\Users\Bebi\AppData\Local\Sony\Vegas Pro\11.0\gpu_video_x86.log
File: C:\Users\Bebi\AppData\Local\Sony\Vegas Pro\11.0\dx_video_grovel_x86.log
File: C:\Users\Bebi\AppData\Local\Sony\Vegas Pro\11.0\svfx_video_grovel_x86.log
File: C:\Users\Bebi\AppData\Local\Sony\Vegas Pro\11.0\dx_grovel_x86.log
File: C:\Users\Bebi\AppData\Local\Sony\Vegas Pro\11.0\vst_grovel.log
File: D:\Bebi\Documents\SONY VEGAS\ausztria.veg
Problem Description
Application Name: Vegas Pro
Application Version: Version 11.0 (Build 700)
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Windows\system32\ole32.dll
Fault Address: 0x77028946
Fault Offset: 0x00058946
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 11.0\vegas110.exe
Process Version: Version 11.0 (Build 700)
Process Description: Vegas Pro
Process Image Date: 2012-09-24 (Mon Sep 24) 15:08:00
Anyone met this problem before? I am trying to render it to wmv as I always do, worked perfectly before. (but I tried mp4, avi, nothing worked)
Dave Osbun
Re: Sony Vegas Pro 11 crashes when rendering iPhone (mov) plus Galaxy S4 (mp4) clips in one edit
on Jul 1, 2014 at 6:11:54 pm
Try rendering using CPU only and see if it works.
Dave
on Jul 1, 2014 at 6:15:29 pm
What do you mean by that? (Sorry I'm not an expert) gpu acceleration is turned off, can't turn it on anyway I don't have a good card)
John Rofrano
on Jul 1, 2014 at 6:19:53 pm
Try setting you RAM Preview to Zero (0) and see if that helps. I just had a 15 minute video that kept getting stuck at 87% and wouldn't go any further. I set my RAM Preview to 0 and it completed without a problem. You can find that under Options | Preferences | Video. Worth a try.
~jr
http://www.johnrofrano.com
http://www.vasst.com
on Jul 1, 2014 at 6:34:58 pm
Thank you, I'll try that! Hope it works! Btw I have 3gb ram.
on Jul 2, 2014 at 11:46:58 am
thank you very much! that worked! can I leave it on 0, what does it affect? it was on 200 before...
John Rofrano
on Jul 2, 2014 at 12:26:40 pm
You can leave it at zero if you'd like. You won't be able to use RAM Preview but if you don't use it there is no problem keeping it at zero. I actually consider it a bug so consider this a workaround.
~jr
on Jul 2, 2014 at 12:34:08 pm
Never met this issue until now, when I edited mobile videos. Will it decrease my render time? During render Vegas used 800mb of my memory, never happened before. Is this because of mobile videos or because ram preview at 0? Anyway what does ram preview actually means? Thanks!
John Rofrano
on Jul 2, 2014 at 8:47:08 pm
RAM Preview is the memory used when you press Shift+B to render a section of video to RAM so that it plays back smoothly. It will also buffer playback when in loop mode. If you never use Shift+B then you don't need to worry about it.
~jr
