Capture video - device not available problems.
COW Forums : VEGAS Pro
Bruce Salmon
on Jun 25, 2014 at 11:33:04 pm
Vegas says that the device is not available when I hook up my camera with the fire wire cable. I can capture the video with the default Windows software but the Vegas doesn't work. When the camera is in EXT. CONT. mode it is recognized by Vegas but you can't capture video in this mode. I have also done a fresh install of Vegas but no joy.
It used to work on my old computer but not now. Any ideas?
SYSTEM
Intel Core I7-3820 3.6GHz
ASUS P9X79 Socket 2011
NVIDIA GeForce GTX 560 Ti
16 GB RAM
Win 7 Pro 64 Bit SP1
Vegas Pro 12 64 Bit Build 770
Video Camera - Canon XHA1
John Rofrano
Re: Capture video - device not available problems.
on Jun 26, 2014 at 11:57:58 am
[Bruce Salmon] "Vegas says that the device is not available when I hook up my camera with the fire wire cable."
Which capture tool are you using within Vegas Pro. There are 2: one of SD capture and one of HD capture. Also make sure that your camera is set up for the same capture options (i.e., SD or HD).
~jr
http://www.johnrofrano.com
http://www.vasst.com
