DNG RAW workflow (Magic Lantern) Sony Vegas Pro 13
COW Forums : VEGAS Pro
Thomas Roberts
on Jun 24, 2014 at 6:37:58 pm
Does anyone do RAW Workflow with Sony Vegas pro 13?
1. Canon DSLR footage
2. Cinema DNG << Does Sony Vegas import Cinema DNG files
3. Magic Lantern RAW workflow with Vegas
Norman Black
Re: DNG RAW workflow (Magic Lantern) Sony Vegas Pro 13
on Jun 24, 2014 at 9:11:48 pm
Vegas does not support Cinema DNG files or Magic Lantern RAW files.
I don't see Sony supporting every RAW format out there. Too much. Hopefully, they will support Cinema DNG as that is multi camera capable.
If you get your RAW exposure setup in some other software and then output an image sequence, you can import an image sequence into Vegas.
Norman Black
on Jun 24, 2014 at 11:16:52 pm
You might look into GoPro Cineform Studio premium. Supposedly some have imported the DNG into that and converted it to Cineform RAW.
Dave Osbun
on Jun 25, 2014 at 5:20:46 pm
Wow, I'm surprised that Vegas doesn't support Cinema DNG, as it's a pretty popular codec.
Warren Eig
on Jun 26, 2014 at 3:22:56 pm
I don't use Vegas as I'm on a Mac, but my workflow is convert the Magic Lantern Raw to CinemaDNG, them open as an image sequence using Camera Raw plugin in After Effects, grade to my liking, save to ProRes QT file and then edit.
You can always relink to originals for a proper grading in Davinci Resolve.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Thomas Roberts
on Jun 30, 2014 at 6:43:13 am
1. Adobe Cinema DNG files? I am shooting Magic Lantern RAW on a Canon DSLR.
2. Is there a program to convert Cinema DNG files to something that is editable and playable for Sony Vegas Pro?
Or is this the final straw for me to leave Sony Vegas Pro....
Warren Eig
on Jun 30, 2014 at 6:45:13 am
You take the Cinema DNG files into Davinci Resolve or After Effects and render out the sequence into something Vegas can read.
Warren Eig
O 310-470-0905
Thomas Roberts
on Jun 30, 2014 at 6:47:39 am
Will this work with the Free version of Resolve?
T
Warren Eig
on Jun 30, 2014 at 6:49:09 am
Yes.
Warren Eig
O 310-470-0905
Russ Froze
on Sep 2, 2014 at 4:01:29 am
Yes I import cdng and dng into vegas Pro from version 10 to 13.
The trick is to instal Adobe dng codec for windows. If you can't find it online I can supply the link.
Russ Froze
Thomas Roberts
on Sep 2, 2014 at 5:27:53 am
Thank you!
Link please?
Russ Froze
on Sep 2, 2014 at 5:55:22 pm
Before I give the url I must explain that dng files in Vegas are slow, but it does work and many things can be accomplished. I use 32-bit floating point (video levels) in the Project Properties. As for the clip properties, the color space I leave as default but you can scroll through the setting to see what works best for you. Another easier workflow is to unpack Magic Lantern raw files with MlRawViewer. It can output a dng sequence or a quicktime mov with Apple prores at 422 a very nice codec that works well in Vegas. White balance, color space or lut can be applied while unpacking. If using mlv in Canon, it will synchronise audio for you that is if you recorded audio. The link to the Adobe DNG code is http://www.adobe.com/support/downloads/detail.jsp?ftpID=5495
If interested in MIRawViewer the link is https://bitbucket.org/baldand/mlrawviewer/downloads
At present I'm using version 1.1.6 it seems stable also it's a good idea to go to the overview page and get a copy of the keyboard shortcuts. Most of the function are accessed by keyboard shortcuts. Hey it's free. Let me know if it woks for you.
Russ Froze
