Add/replace soundtrack to video without re-render/encode
COW Forums : VEGAS Pro
Mariano de la Cruz
on Jun 11, 2014 at 2:24:22 pm
Hey folks! Ive a question regarding Vegas (or some other program can be also). I have the original video files which came right out of the camera and i want to replace that sound with the recorded one so its synchronized. Is there a way to avoid rendering after so you can get the job done quicker?
Regards,
M
Stephen Mann
Re: Add/replace soundtrack to video without re-render/encode
on Jun 11, 2014 at 2:50:55 pm
No. Well, it depends. But generally, no.
If you use a video codec that can be smart-rendered (search the help file) then it should do the final render faster. But that depends on what you are rendering to. And from, for that matter.
Steve Mann
MannMade Digital Video
http://www.mmdv.com
Gabriel Meono
on Jun 11, 2014 at 10:33:24 pm
Use avidemux,
You simply render your audio track, open avidemux and replace the audio channel with the new audio track, export settings as copy.
Here's a video tutorial for that:
