Creating a "flashback" or "remebering the past" visual/audio effect
COW Forums : VEGAS Pro
Clay Nichols
on Jun 6, 2014 at 10:45:09 pm
Is there an easy way (or inexpensive addon) to create an effect (visually and with audio) to cue the viewer that we are now flashing back to a scene in the past?
The standard way I've seen this is sort of a shimmering /wavy disolve and something like harp music.
It's funny, I see all these visual transition effects in Sony Vegas (and in Pinnacle Studio) and wondered "how do you pick one"?
Then I realized you start with the concept you're trying to communicate:
- Time has passed
- Someone is thinking of /imagining something (that the next scene shows)
-Someone is remembering the past.
Seems like organizing the Transition Fx around that would make more sense.
Selina Young
Re: Creating a "flashback" or "remebering the past" visual/audio effect
on Jun 7, 2014 at 8:05:00 am
If you don't want to use any FXs...
You could transition to the 'flash back clip(s)' through white and make the 'flash backs' look like old-early footage by either reducing the colour saturation / adding noise / vignetting / etc - depending on how far back in time and/or the emotional connection of the 'flash back' to the subject.
Or you could use two black (dark orange/brown) solids and animate them to look like someone shutting their eyes and increasing blur to the 'transition' then fade to the 'flash-back' clip.
Or you could focus in on the subject's face and fade to 'flash-back'.
If you want to use audio to emphasize the fact that you are returning to the past... you could gradually add echo / reverb to the subject's words that cue the flash-back...
Hope the ideas help - but, of course, there is no better way than to analyse what the pro's do and adapt to your particular need...
Clay Nichols
on Jun 7, 2014 at 3:14:05 pm
And doing with an FX is fine too.
Your suggests are good but I'm hoping for a simple Transition FX
Selina Young
on Jun 7, 2014 at 10:04:09 pm
Here's something you might find interesting and perhaps you can adapt it to suit your needs - it uses a lot of effects ;)
http://library.creativecow.net/articles/rabinowitz_aharon/CC_Flashback/vide...
