Vegas 12 render problem
COW Forums : VEGAS Pro
Greg Warren
on Jun 3, 2014 at 2:40:16 am
Hi All. I'm working on an project rendered to Blue Ray. The playback in DVDA is stuttering a lot with the camera moves. I found a thread with a google search to turn off the GPU accelerator and that did not help. I did the render with the GPU on and off and am still getting the jitter. Any help would be appreciated!
Thank you!
Greg
john bolton
Re: Vegas 12 render problem
on Jun 3, 2014 at 4:03:24 pm
Can you explain a bit more what JITTER actually looks like. Do you mean like fuzzy or interlace issues.. Can you post a small clip of the problem or post a screen shot of the JITTER....
Greg Warren
on Jun 3, 2014 at 4:53:57 pm
John
I'll try to post a clip. The issue for example is when the camera pans left to right the video stutters and it not a smooth looking move. This is after the rendering. When I'm working on the timeline in Vegas the footage is smooth. It looks like the camera is "jerky" for lack of a better term.
Greg
Greg
John Rofrano
on Jun 4, 2014 at 1:58:18 am
[Greg Warren] "The issue for example is when the camera pans left to right the video stutters and it not a smooth looking move."
Are you rendering to a lower frame rate than the source video? This could cause stuttering if you disabled resample and the movement is too fast.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Greg Warren
on Jun 4, 2014 at 2:10:59 am
John
I think I resolved this by using the Sony render settings instead of Main Concept. The footage was smooth when I reviewed on DVDA. Thank you!!
Greg
John Rofrano
on Jun 4, 2014 at 1:04:43 pm
[Greg Warren] "I think I resolved this by using the Sony render settings instead of Main Concept. The footage was smooth when I reviewed on DVDA."
Very interesting. Glad you figured it out.
~jr
