Where are recently used projects stored?
COW Forums : VEGAS Pro
Paul Gregory
on Jun 2, 2014 at 1:12:54 am
Where are recently used projects stored? The reason that I ask is that you are allowed a max of nine. I recently deleted from my PC some that were no longer needed. But what I see that they still appear on this list & there failure to be removed appears to prevent other older ones to appear.
Thanks in advance
Norman Black
Re: Where are recently used projects stored?
on Jun 2, 2014 at 2:08:18 am
The list is fixed in size and removing something will not cause something older to re-appear. The list is populated as you open projects. If you select a project which has been deleted/moved then, you get an error opening and it will simply be removed from the list and the list will contain one item less than before.
Aleksey Tarasov
on Jun 2, 2014 at 2:18:25 pm
Vegasaur Project History has no limits ;)
