How to keep fast frame changes crisp looking as on original?
COW Forums : VEGAS Pro
Jaanus Henno
on May 30, 2014 at 5:49:57 am
Hi!
I have some mp4 files recorded with a Samsung Galaxy2 smartphone.
The problem I have is after editing and rendering I don't get satisfying results in regards of how the video is changing from frame to frame. That is happening when some movement is present, it looks washed away. I tried different options and framerates, but still the same problem.
I guess that's an interlacing problem, I'm not so aware of all those little details.
The source file is progressive, frame rate (Mediainfo) 24,474 1920x1280, AVC Baseline L4, 1 Ref frame.
My output would be mp4 for youtube.
john bolton
Re: How to keep fast frame changes crisp looking as on original?
on May 30, 2014 at 7:25:41 am
Have to tried to turn off - DISABLE RESAMPLE - in the Event Properties?
Jaanus Henno
on May 30, 2014 at 8:09:49 am
Holy cow, that worked! Thanks!
Btw. Should I always disable it? Or is it just with certain files?
Jaanus Henno
on May 30, 2014 at 8:35:48 am
Ok, I reply myself after studying the topic a little further.
One answer from a forum:
I disable re-sampling for the following:
*speeding things up
*want a stutter in slower speed
*the "smoothness" looks bad when I slow something down and it's better to have a stutter.
I have one more question. Is there something intermediate or a way to actually control sampling? What I mean is to somehow be able to tweak sampling so that I can choose the best option between jerking frames and too much ghosting.
John Rofrano
on May 30, 2014 at 11:36:07 am
[Jaanus Henno] "I have one more question. Is there something intermediate or a way to actually control sampling? What I mean is to somehow be able to tweak sampling so that I can choose the best option between jerking frames and too much ghosting."
No, there is not. Resampling is either on or off, on an event by event basis; there is nothing to tweak. The Auto setting use to work well in the days of DV but with HD formats it doesn't do a good job so you need to manually control this. I wish Sony would fix it.
~jr
http://www.johnrofrano.com
http://www.vasst.com
