vegas 12 dvd off timeline burn
COW Forums : VEGAS Pro
Howard Steiger
on May 30, 2014 at 5:15:12 am
i tried loop playback. it renders then prepares dvd for burn but fails to burn on multiple recorders. can it be done and if so how? thanx
Graham Bernard
Re: vegas 12 dvd off timeline burn
on May 30, 2014 at 6:04:30 am
_______________________________________________________________
[Howard Steiger] "but fails to burn on multiple recorders."
What do you mean Howard? What do you want to do?
Is it:
A] Do you want to simultaneously burn to MANY Burners?
. . or is it . .
B] Are you getting failure to swapping to other Burners?
If it is "A" then I have never seen read and heard of that as being an option directly from the Vegas Timeline. If it is "B" then you;d need to investigate each and every Burner. Yes?
Sorry, I'm not being very helpful.
Grazie
Howard Steiger
on May 30, 2014 at 6:16:00 am
vegas 12 has a known issue of burning dvds off timeline just wanted to know the fix it fails to work
