downbeat pointer
COW Forums : VEGAS Pro
Andrew Gordon
downbeat pointer
on May 27, 2014 at 9:39:26 pm
I would like to add a downbeat pointer for every measure so that someone watching the video knows where they are in the chord progression, any suggestions for the best way of going about this would be appreciated.
John Rofrano
Re: downbeat pointer
on May 28, 2014 at 12:47:25 pm
[Andrew Gordon] "I would like to add a downbeat pointer for every measure so that someone watching the video knows where they are in the chord progression, any suggestions for the best way of going about this would be appreciated."
You could just make a colored vertical bar that moves to the beginning of every measure to show what measure you're on. This can be created using Generated Media and animated with Track Motion. You could also highlight the current measure with a box or yellow overlay. Some Wingding fonts have a hand with a finger pointing. You could simply use the Text generator to move the pointing finger to the start of each measure at the down beat. Make it a nice bright color that's easy to see.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Andrew Gordon
on May 30, 2014 at 12:57:45 am
Hi John,
Thank you for your reply, I used the text generator and it works great, just takes time to line up the pointer to each measure.
John Rofrano
on May 30, 2014 at 6:08:11 pm
Great! I'm glad that worked out for you.
~jr
