DVDA want to to remove a button that doesn't appear on menu.
COW Forums : VEGAS Pro
Paul Gregory
on May 23, 2014 at 9:26:42 am
I can't proceed with a DVDA project because it says the 'inactive button default color should be set to none' on my menu. There is no buttons on this menu. How do I fix this?
Thanks in advance
Stephen Mann
Re: DVDA want to to remove a button that doesn't appear on menu.
on May 23, 2014 at 4:35:15 pm
Set it in the Menu Page Properties (alt-8).
But, I am not sure how you would get this warning because you can set the button color sets whether you have buttons or not.
Steve Mann
MannMade Digital Video
http://www.mmdv.com
Paul Gregory
on May 24, 2014 at 3:14:56 am
I think that the problem might have been because for the first time ever I had used a theme for which all I altered was the default text. I looked where you suggested but found nothing that I could change. Rather than waste time I just restarted the menu from scratch & it worked OK.
At the moment I'm trying to do a test burn onto a re writable Blu-ray disk but the programs tells me that there is still data on it that I will have to erase. I have 2 programs which say that there is nothing on the disk so as you can see its always something. So I'll just have to wait & see how it turns out
Thanks in advance
