Vegas on 64bit Windows a tad laggy
COW Forums : VEGAS Pro
Morgan Lewis
on May 17, 2014 at 1:54:36 pm
I've recently updated to Windows 7 from XP, using the same Vegas I used in XP, Pro 10C, but this time the 64 bit one.
I have 4 gigs of ram and an i5 quad core, Task manager doesn't say anything's maxing out, but while I work with vegas I usually have a text file open to make any notes I need, since moving to Windows 7 and the 64bit version every time I click my text file, or minimise Vegas, when I bring vegas back up the cursor turns to the busy animation for a second or so before I can continue using the program.
I can see this getting annoying in the future, what could be causing it to stall briefly like this when the CPU and RAM aren't being maxed out?
Norman Black
Re: Vegas on 64bit Windows a tad laggy
on May 17, 2014 at 2:43:48 pm
In your preferences you can clear option for, Close media files when not the active application.
This will save time since Vegas does not have to check and re-open all the files. The only time you need this option checked, is when you want to edit a file Vegas is using, without closing Vegas, and then come back to Vegas.
Morgan Lewis
on May 17, 2014 at 2:50:10 pm
That fixed the issue, thanks for such a quick reply. I don't think I'll ever need to edit a file vegas is using, but I'll keep that in mind if I do, cheers.
Steve Rhoden
on May 18, 2014 at 8:10:35 pm
It would also be in your best interest to add a little bit more Ram.
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
http://www.facebook.com/FilmexCreativeMedia
1-876-461-9019
