Trouble making a transition occur within a mask
COW Forums : VEGAS Pro
Andy Weilbaecher
on May 12, 2014 at 5:31:38 pm
I have a series of 3 images that I want to rotate in 3 other images from behind.
When I do a transition however, the tranistion occurs within the entire 1920x1080 screen.
I would like the transition to occur within the exact height of the image
so it will look smoother, Like a cube with with different images on each side.
Is there an easy way to do this that I'm missing like cropping the track area?
John Rofrano
Re: Trouble making a transition occur within a mask
on May 14, 2014 at 12:59:31 am
[Andy Weilbaecher] "Is there an easy way to do this that I'm missing like cropping the track area?"
You're on the right track (no pun intended) ;-) You want to use Track Motion to make the images smaller. That will make the whole track smaller and the transitions will only occur within the smaller track area. In effect, "cropping the track area".
~jr
http://www.johnrofrano.com
http://www.vasst.com
