error installing Sony Vegas 13 Pro
COW Forums : VEGAS Pro
Grzegorz Kwiatkowski
on May 12, 2014 at 10:11:36 am
I still can't install Sony Vegas 13 Pro. I tried on different computers.
I get this error:
"ERROR: -2147163964 occured during installation
Module C:\Program Files\Vegas Pro 13.0\x86\sfvstproxystubx86.dll failed to register.
HRESULT -147024703. Contact your support personnel".
thanks for help
Steve Rhoden
Re: error installing Sony Vegas 13 Pro
on May 12, 2014 at 10:18:16 am
Is this with the latest Build 310 update?
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
http://www.facebook.com/FilmexCreativeMedia
1-876-461-9019
on May 12, 2014 at 10:33:05 am
Yes
John Rofrano
on May 12, 2014 at 12:52:35 pm
[Grzegorz Kwiatkowski] "Module C:\Program Files\Vegas Pro 13.0\x86\sfvstproxystubx86.dll failed to register. HRESULT -147024703. Contact your support personnel"."
Hmmm... Perhaps some other software on your system is conflicting the 32-bit VST proxy stub and causing it not to register? Do you have other audio software installed that might be causing this?
~jr
http://www.johnrofrano.com
http://www.vasst.com
Stephen Mann
on May 12, 2014 at 12:52:42 pm
From what Version? What O/S?
It shouldn't matter, but a large negative number for an error number often says you have encountered a 64-bit instruction in a 32-bit environment.
Steve Mann
MannMade Digital Video
http://www.mmdv.com
Mike Kujbida
on May 12, 2014 at 1:09:15 pm
Move your VSTs into a completely different folder so that Sony does not see them during installation.
If you can now install Pro 13, copy them back a few at a time into your Sony VST folder until you find the problem one(s) and leave them in the new folder.
Re: rror installing Sony Vegas 13 Pro
on May 12, 2014 at 2:19:55 pm
It doesnt work.
Eddie Dorsey
on Sep 6, 2014 at 9:50:29 pm
Not sure if you've gotten your situation fixed, but try this: Look for Microsoft C++ Redistributable 11.0.61030. Install both the 32-bit and 64-bit versions, then try your install again. (If you have these already, repair the install or reinstall.) Lemme know if it works out for you.
