Raw smaller size clips render faster
COW Forums : VEGAS Pro
Julius Zabulenas
on May 11, 2014 at 10:15:00 am
Hello, im creating videos, uploading them to youtube and so on for a long time. Have been messing up with the settings, renderings and so, but this post is kinda not about it.The question is, as example, will sony vegas render clips faster if the imported files (aka raw files) are smaller sizes? Because i record all my videos with Lagarith codec, size doesn't matter for me (if you know what i mean), and if im gonna record with more compressed codec like bandicam or so which will make file size of recorder clip smaller, render faster? 10 min clip in lagarith takes up 3gb, with a bandicam codec (or even xvid x264) it would be 200-300mb. Without further or do, as i said, question is will the whole rendering process be faster if i will render from files which are smaller sizes?
John Rofrano
Re: Raw smaller size clips render faster
on May 11, 2014 at 3:33:07 pm
[Julius Zabulenas] "if im gonna record with more compressed codec like bandicam or so which will make file size of recorder clip smaller, render faster?"
The answer is probably NO, it will take longer to render. The size of the file is not the issue. The amount and complexity of the compression is the problem. Lagarith uses very light-weight compression that is very easy to process. AVC/H.264 uses heavy compression that is very difficult to process, so the smaller AVC/H.264 files will take longer to render than the Lagarith files.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Julius Zabulenas
on May 13, 2014 at 3:59:34 am
Thank you very much for detailed explanation. Just had a minor thought about it, but its the same! Thanks again!
John Rofrano
on May 13, 2014 at 10:58:10 am
You're welcome. Glad I could help.
~jr
