Best software to convert into uncompressed before importing to Vegas Pro 12
COW Forums : VEGAS Pro
Jaanus Henno
on May 10, 2014 at 3:13:32 am
Hi!
I have some Mp4 files that cannot be opened in Vegas Pro 12. Nevermind the details, my question is what program/coverter do you usually use to get those unfriendly files into Vegas? My idea is to convert them into uncompressed AVI to get them into Vegas and do the rest. And I also include file details by Mediainfo:
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 79.3 MiB
Duration : 1mn 14s
Overall bit rate mode : Variable
Overall bit rate : 8 977 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Coding Efficiency@L4
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 1mn 14s
Bit rate mode : Variable
Bit rate : 9 000 Kbps
Maximum bit rate : 14.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.326
Stream size : 78.7 MiB (99%)
What converters are best and what settings are best?
Thanks in advance.
John Rofrano
Re: Best software to convert into uncompressed before importing to Vegas Pro 12
on May 10, 2014 at 2:45:22 pm
[Jaanus Henno] "My idea is to convert them into uncompressed AVI to get them into Vegas and do the rest."
Unless you have a RAID 0 array to handle the throughput required by the extremely large uncompressed video files I would strongly discourage this approach.
From your Mediainfo it looks like "Codec ID : MSNV" is what's throwing Vegas. These looks like Sony Cyber-Shot files. You can convert them to Motion-JPEG with a tool like AviDemux 2.5 or you can just use something like Handbreak to convert them to a more friendly MP4 file.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Jaanus Henno
on May 11, 2014 at 9:55:46 am
Thanks John, Handbrake did a great job.
John Rofrano
on May 11, 2014 at 11:20:33 am
Yea, for a free encoder it does an outstanding job. Glad it worked for you.
~jr
