Quick framerate ?
COW Forums : VEGAS Pro
Scott Francis
Quick framerate ?
on May 10, 2014 at 2:58:13 am
I am working with 29.97 and 59.94 FPS footage in the same project, any thoughts on which I should set my project for to get the best preview?
Scott Francis
Mind's Eye Audio/Video Productions
Norman Black
Re: Quick framerate ?
on May 10, 2014 at 2:44:00 pm
With either choice Vegas is going to have to do some resampling.
Which one do you have more clips of? Choosing this would minimize the amount of resampling done by Vegas.
What is your intended output target. 30 or 60p. You might choose that. 30p is always easier for Vegas to edit than 60p by a good margin so you should look at this unless you require a 60p output.
In "preview" preview window mode. Vegas always skips a full frame rate resample. This is as if you had "disable resample" checked on all events. This will be your quickest preview mode.
Disabling resampling on everything will speed preview and most people do not like the frame blending Vegas does anyway.
