Using AMR audio
COW Forums : VEGAS Pro
Paul Gregory
Using AMR audio
on May 4, 2014 at 1:11:53 am
I have a small AMR audio file from a phone that I would like to use some of the audio. Rather that purchasing a converter program for minimal usage I thought I would ask is there any other alternative to doing this. If necessary I could always revert to one of these programs that can record what you hear playing on the PC.
Thanks in advance
Bob Peterson
Re: Using AMR audio
on May 4, 2014 at 12:57:31 pm
Vegas itself can record audio. If you set up an audio track on the timeline, you will find an icon on the far left of the track controls that is "arm for record" and next to it is a "record input" control. I have not used this for a long time, but I'm pretty sure it will record whatever source is selected in Windows for recording.
Paul Gregory
Re: Using AMR audio
on May 5, 2014 at 4:23:29 am
Thanks for that reminder. It works well. The only downside that I can see is if you wanted to record a long clip as that its done in real time.
Thanks in advance
Steve King
Re: Using AMR audio
on May 5, 2014 at 7:51:44 pm
There are many free audio file converters. This one, http://www.nch.com.au/switch/index.html, will convert from .amr files to .wav files, which should do what you want.
