Sony Vegas pro 12-13 sound choppy after cut
COW Forums : VEGAS Pro
Christian Karström
on Apr 28, 2014 at 4:09:36 pm
Hi guys! I have a really annoying error. If you want the best explanation of what's wrong then check this youtube video -
If you don't want to check that video then i'll try to explain it as good as I can.
When i press S in order to cut a audio clip, in the beginning of the second clip the audio gets choppy.
It's still choppy if I turn of all audio effects. I tried switching between vegas pro 12 and 13, still there. Tried making different tracks. Still there.
BUT if i play the track from the beginning of the second clip it's not choppy. So it's not the sound file. And when I render it it renders choppy. Tried WAV and MP3, choppy with both.
I've never encountered this problem before and it kinda baffles me.
Thank you in advance!
Graham Bernard
Re: Sony Vegas pro 12-13 sound choppy after cut
on Apr 28, 2014 at 10:20:06 pm
Hi Christian, does your Audio sample rate of the Media match your Project Settings? Also, this sometimes clears after a reboot.
I'm hearing (VP13 B270) the same with VSTs - nasty.
Please report this to SCS.
Grazie
