How to open MPG-4 file?
COW Forums : VEGAS Pro
Senna Bsc
on Apr 26, 2014 at 3:24:41 pm
Hi guys please help me I'm not familiar with extensions and formats... can this file be opened in Sony Vegas and how?
video.............: MPG-4@~ 1460 Kbps
audio.............: MP3@~128 Kbps
reza..............: 704 x 400 @ 25.000 fps
format............: avi
source............: DVB
John Rofrano
Re: How to open MPG-4 file?
on Apr 26, 2014 at 6:58:25 pm
Vegas doesn't support MPEG4 in an AVI container by default. You can try installing the x264vfw codec and see if it will open. Make sure that you use the 64-bit version of the codec if you are using the 64-bit version of Vegas Pro. Whatever you do, DO NOT install codec pak like K-Lite. It will mess up Vegas.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Senna Bsc
on Apr 26, 2014 at 11:01:49 pm
Thank you jr, I installed x264vfw codec and it's ok now, the file can be imported ;)
Do you also know is there any codec to open flv files (clips from youtube) or mkv files?
For example, when I import this file I only get audio track.
video.............: x264@~ 1000 Kbps
audio.............: AAC@ 48 KHz
format............: mkv
John Rofrano
on Apr 27, 2014 at 11:52:41 am
[Senna Bsc] "Do you also know is there any codec to open flv files (clips from youtube) or mkv files?"
No, there is not. You would need to convert those to an editable format with anther program before bringing them into Vegas Pro.
~jr
hartseri Paul
on Apr 29, 2014 at 2:54:20 am
FLV is not a acceptable format for Sony Vegas. I suggest you use something like AppGeeker Converter and convert the .flv file to something like .mp4 or .avi.
http://www.appgeeker.com/how-to/convert-flv-to-mp4-mac.html
Sony Vegas supported file; H.264, HDP, IVC, JPEG, M2T, M2TS, MOV, QT, Sony MXF (XDCAM and HDCAM SR), MP4, MPEG-1 and MPEG-2 video, AVC, AVCHD, AVI, WMV
