Writing Scripts / Magic Lantern
COW Forums : VEGAS Pro
Matthew Jeschke
on Apr 22, 2014 at 3:14:11 am
My background is programming... However, I've never worked with Sony Vegas and would like to.
Has anybody here wrote scripts? I found the SDK here, http://www.sonycreativesoftware.com/download/devkits
I'm assuming that's where to start. I'd like to create tools to handle magic lantern HDR clips & RAW video in Vegas w/o all the extra software / headache.
Maybe it's a lofty goal but would like to see how far I can get :)
I'm learning the ropes of online publishing. Mostly as an excuse to play with more cameras.
Here's several of my latest ventures,
http://www.keystoaz.com
http://www.fitlish.com
http://www.corvettemedic.com
Steve Rhoden
Re: Writing Scripts / Magic Lantern
on Apr 22, 2014 at 9:07:47 am
Yep, that's where to start.
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
http://www.facebook.com/FilmexCreativeMedia
1-876-461-9019
John Rofrano
on Apr 26, 2014 at 12:23:40 pm
If you can describe what you need to do, I can point you in the right direction with regard to what API calls to read up on.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Russ Froze
on Aug 10, 2014 at 2:45:36 am
Here is something that might be of use. By some fluke I managed to import the Magic lantern DNG files directly into Vegas Pro. Versions 10 - 13. The trick it seems is to install Adobe - DNG Codec - For Windows - Adobe DNG Codec 2.0.'>Adobe - DNG Codec - For Windows - Adobe DNG Codec 2.0. It's a bit sluggish but it avoids hours of transcoding and the like. Using the MIRawViewer adjusting the white balance in conjunction with various other tools supplied with the viewer before exporting the DNG files is a real time saver. To finish off color grading I use Boris Red from the Vegas timeline where I can use the Three way color grade plugin. I'm curious to know if I am the only one to stumble across this workflow. I have it working on three separate machines now.
