Binding Excalibur Scripts to Keyboard in Vegas
COW Forums : VEGAS Pro
Frankie Jones
on Apr 20, 2014 at 4:14:18 am
I use the Select Events to End Script in Excalibur a lot in Vegas, and wondered if it was possible to bind it to a keypress, to save me mousing to the toolbar to click it each time.
Best,
Frankie
Graham Bernard
Re: Binding Excalibur Scripts to Keyboard in Vegas
on Apr 20, 2014 at 6:16:52 am
[Frankie Jones] "
I use the Select Events to End Script in Excalibur a lot in Vegas, and wondered if it was possible to bind it to a keypress"
Sure, and this in VP13, should be same for VP12:
Go: Toolbar > Options > Customize Keyboard
Click Trackview and enter Excalibur in the "Show commands containing" and you should get this, with all the available Excalibur commands:-
You can see I've now setup the Select Events as a keyboard shortcut as Ctrl+X+E, (for ease of remembering : X=eXcalibur and E=Events) but you could set it with any keyboard combo of key presses that aren't already in use.
Cheers
Grazie
Frankie Jones
on Apr 20, 2014 at 9:35:20 pm
Thankyou very much, very helpful
Edward Troxel
on Apr 21, 2014 at 6:14:44 pm
If you go to the "About" tab in Excalibur, you can also open the help file which explains this process as well.
Edward Troxel
