Script for sync (time date)
COW Forums : VEGAS Pro
leaning less
on Apr 17, 2014 at 3:22:29 pm
Hi! Is there a script for synchronisation mov-files according to the time date with high precision (up to the fractions of seconds)?
I'm have used that script but it doesn't satisfy me, or i don't use it correctly.
7379_synchr.cs.zip
Grzegorz Kwiatkowski
Re: Script for sync (time date)
on Apr 18, 2014 at 2:02:09 pm
Try Vegasaur. It has the option to sync media using date modified file attribute.
leaning less
on Apr 18, 2014 at 3:35:19 pm
I have Vegasaur 1.9.4 Try version, but can't find this function. Please tell me.
on Apr 18, 2014 at 3:40:17 pm
it is not so obvious. I am not in front of my computer right now but I think you will find it somewhere in Quick Properties. Sort files using date modified.
leaning less
on Apr 18, 2014 at 3:47:56 pm
Looked again, but found only sort events chronologically.
on Apr 18, 2014 at 4:08:25 pm
It should be under PLACEMENT tab. Sync using date modified.
leaning less
on Apr 18, 2014 at 4:24:10 pm
It's strange, but I don't have placement tab
leaning less
on Apr 19, 2014 at 4:25:05 am
I think I found it in the quick propeties.
on Apr 19, 2014 at 7:15:24 am
Exactly. Does it work for u?
leaning less
on Apr 19, 2014 at 2:51:35 pm
It works. but date modified from canon dslr aren`t correct. For example, if date modified of the first file is 00:00, then in its minute duration the date modified of the next file can be shown as 00.50. Have you encountered this problem?
Recorded time/date is missing :(
