First blu-ray authoring attempt.
COW Forums : VEGAS Pro
Tim Maddoux
on Apr 7, 2014 at 8:27:09 pm
Greetings All!
After creating my first blu-ray in DVDA, I tested it in a sony blu-ray player and had an interesting result.
After playing the intro media the player went back to its beginning default state like I had press the stop button. It never moved past the intro media to the menu selections.
I can't see reasons why this is happening.
Any help is greatly appreciated
Chris Hewitt
Re: First blu-ray authoring attempt.
on Apr 8, 2014 at 2:14:13 pm
Hi Tim, I think I can help you with that problem.
For the 'First Play settings, the End Action should read 'Menu-Start'. The same applies for the Remote Control settings or the disc won't play past the First Start file, especially for BluRay although the same applies for DVD.
I did have this problem and took me a while to find a solution but the above did work for me and no problems since.
Hope this helps.
Tim Maddoux
on Apr 9, 2014 at 2:41:57 am
Thank you so much Chris! That was it.
Appreciate you man!
