NeatVideo results for different GPUs are needed
COW Forums : VEGAS Pro
Mikhail Petrushin
on Apr 7, 2014 at 1:59:21 am
I've made a tiny web-page with NeatVideo results:
http://fifonik.com/nv/
The information about this database in NeatVideo forum:
http://www.neatvideo.com/nvforum/viewtopic.php?t=1002
This page could be usefull for comparing/choosing GPUs for video editing (especially if you use NeatVideo).
Unfortunately, I do not have NeatVideo results for many GPUs, so for now this page is almost useless.
However, you can help me by posting results for your GPUs :)
Just open the page (no registration required), press "Add your results..." button, choose your GPU and NeatVideo version from lists, and paste your optimize log in the textarea. Optionally you can fill in you name and system info (CPU, RAM, OS and video driver version).
To get optimize log in NeatVideo in menu click Tools | Preferences | Performance | Optimize..., choose parameters and press Start button.
It would be nice if you post your results twice at for 1920x1080 p, 8-bit colour depth, radius=0 and radius=5.
Thanks.
Graham Bernard
Re: NeatVideo results for different GPUs are needed
on Apr 7, 2014 at 6:00:31 am
Interesting Tool. What has driven you to do this?
Grazie
Mikhail Petrushin
on Apr 7, 2014 at 7:19:22 am
Since video editing had became my hobby I updated my video card twice. Every time I dug Neat Video support forum for the information about video card's speed in Neat Video (I use Neat Video plugin quite a lot time).
I bet that was not the last time when I upgraded my video card, so I decided to spend some time and make easy tool where people will be able to post their results. So it will be easy to compare different video cards' speed in Neat Video. This tool could be usable not just for me, but for other Neat Video users as well.
P.S. It did not take much time as I am web developer.
John Rofrano
on Apr 7, 2014 at 11:36:49 am
[Mikhail Petrushin] "It would be nice if you post your results twice at for 1920x1080 p, 8-bit colour depth, radius=0 and radius=5."
I'd like to help but neither of my video cards (NVIDIA Quadro 4000 & ATI Radeon HD 5870) are in the list. :(
I also have a real problem with Neat Video's policy of charging you again, and again, and again, for each NLE that you own. No other software I've encountered has had such a byzantine policy. If I buy a plug-in, I should be able to use my license in whatever NLE's I own that it supports. For this reason alone, I stopped using Neat Video but I do have an old copy for Vegas Pro around somewhat that I could test if my cards were in the list. It's probably version 2. I don't think I upgraded to 3 because of their license policy. If you only want version 3 results then I can't help you (sorry). Get them to change their license policy and I might upgrade.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Jorge Talamantes
on Nov 23, 2016 at 4:23:31 am
it says error while adding data
10822_8bitradius01080p.txt.zip
Ole Kristiansen
on Nov 23, 2016 at 12:33:37 pm
"LOG INFO neat video 3.5 with i7 2.66 ghz 12gb ram amd driver 15.7.1
4 GPUS"
The latest AMD video driver does not support GPU OpenCL in Neat Video Noise Reduction
https://forums.creativecow.net/thread/24/1014458#1014458
