How do I monitor the mic in pre-recording mode?
COW Forums : VEGAS Pro
Ronly Maller
on Mar 23, 2014 at 7:20:15 pm
Hi.
How can I monitor my mic in pre-recording mode with my headphones?
I can hear it only after I recorded something..
Graham Bernard
Re: How do I monitor the mic in pre-recording mode?
on Mar 23, 2014 at 10:20:37 pm
Where do you have your Cans plugged into?
G
John Rofrano
on Mar 26, 2014 at 12:37:31 pm
[Ronly Maller] "How can I monitor my mic in pre-recording mode with my headphones? I can hear it only after I recorded something.."
Input monitoring only works with audio devices that have ASIO drivers. Does your audio device have ASIO drivers? If not, you should invest in a professional audio device that does. You can try a generic ASIO driver like ASIO4ALL but if you are serious about recording, you should invest in a good audio capture device. BTW, these devices will have a headphone jack on the device so that you have the option to monitor the clean mic signal in hardware before it gets to Vegas Pro.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Graham Bernard
on Mar 26, 2014 at 4:33:03 pm
I have this Presonus AudioBox. Its ASIO drivers work well with Vegas. It has only 2 x XLR/Jack Combo inputs, Phantom power, but does have full control and Monitoring to Cans prior to hitting Vegas. I bought it to get my mic-IN free from any low level noise, but subsequently recognize the value of the INs and OUTs.
It raised my game.
Grazie
John Rofrano
on Mar 26, 2014 at 7:42:18 pm
[Graham Bernard] "I have this Presonus AudioBox."
Yea, the AudioBox is a great interface. I use an M-Audio Firewire 410 on my PC workstation and an M-Audio FastTrack Pro on my MacBook Pro via USB. Both provide ASIO and hardware monitoring. If you want to hear the FX that you have applied to a track you want to monitor from within Vegas Pro.
~jr
