Eliminating audio hum from camera
COW Forums : VEGAS Pro
Jane Wielecki
on Mar 15, 2014 at 12:35:42 pm
Hello,
I am using Sony Vegas Pro 10 (64 bit) and editing Standard Definition footage from 2005 (PAL 720 x 576). The editing is almost complete. There is a hum in the audio from the camera in a number of sections which I want to eliminate. Is Sound Forge Audio Studio 10 the best tool for this?
Any advice would be much appreciated.
Thank you, Jane
Mike Kujbida
Re: Eliminating audio hum from camera
on Mar 15, 2014 at 2:10:40 pm
I don't see a noise removal plugin on the features list for Audio Studio but if you can upload a WAV file of one of the sections, we can play with it and let you know the best way to attack the problem.
Frank Stevn
on Mar 15, 2014 at 2:21:40 pm
Get Audacity (http://audacity.sourceforge.net/)
Render the audio as WAV and do like this:
http://wiki.audacityteam.org/wiki/Noise_Removal
Angelo Mike
on Mar 15, 2014 at 3:08:08 pm
Audacity works well (look up Bill Meyers' video on how to remove it using audacity), and you can also use the Track EQ plugin and drag down the "4" in the plugin window until you get the right amount of hum removal without affecting the other sound too much.
Ryan McRobb
on Mar 16, 2014 at 7:35:05 am
You should get a copy of Izotope RX3 noise removal software.
This works unbelievably well, it can take remove noise from single files that have noise in the same frequency bands as the sounds you intended to record.
Jane Wielecki
on Mar 22, 2014 at 9:29:47 am
Hi Ryan
I downloaded the trial version of Izotope rx3 and I love it. It's awesome. I'm buying it!
Thank you for advice. Regards, Jane
