Jittery / Jerky video during pan motion
COW Forums : VEGAS Pro
Brad Miller
on Dec 20, 2010 at 3:38:16 am
How can I get smooth movement during pans? As seen in the following video, the pan motion is very jittery/jerky. I tried render at 60fps, as well, and it's still bad. I can create the same video in After Effects and it's perfectly smooth, but it's a lot easier to do in Vegas.
Steve Rhoden
Re: Jittery / Jerky video during pan motion
on Dec 20, 2010 at 4:13:16 am
Just simply do those kind of motion graphics in After Effects if you have it...Its made for it.
Steve Rhoden
(Cow Leader)
Creative Arts Director and Film Maker.
Project Samples at:
http://www.youtube.com/hentys
Brad Miller
on Dec 20, 2010 at 4:29:19 am
I understand that... but Sony Vegas Video is supposed to be able to do this. This is just a simple pan motion of one static jpg image. It would nice to be able to do something Vegas is made to do without having to use another program.
Saying just use AE is like saying just use Premiere while I'm at it.
Stephen Mann
on Dec 20, 2010 at 3:07:25 pm
show us the Vegas results. I've done this in Vegas with no jerkiness.
Steve Mann
MannMade Digital Video
http://www.mmdv.com
Brad Miller
on Dec 20, 2010 at 3:23:27 pm
It's the video embedded in my first post.
Here's a direct link:
Guillaume Jeffrey
on Dec 21, 2010 at 8:23:44 am
I ran into the same problem some time ago.
The only workaround I found was slowing down the pan and add a slight motion blur to the event.
john bolton
on Dec 21, 2010 at 4:03:49 pm
The way I overcome it was to make the project with the frame rate @ 100 FPS ( or any higher number ) , None Progressive scan - Blend fields and then the timeline images set Reduce interlace flicker and Non Progressive and render as None progressive with 60 FPS and it is very smooth. Using standard FPS in the project is jerky. Worth a try for you John
Brad Miller
on Dec 21, 2010 at 4:20:23 pm
I'll give that a try. Good idea.
Once you rendered it at that frame rate, and added the rendered clip to a 30fps project, was it still smooth in the final project?
john bolton
on Dec 21, 2010 at 4:58:10 pm
Hi there .. I added the MPEG file to a video which was @30FPS and rendered again and it ws still looking OK.
Luke Adams
on Jan 3, 2011 at 1:53:57 pm
Hey, I am having the same issues. I have a project that consists entirely of jpegs in Sony Vegas Movie Studio, and some of my pans/zooms seem to jitter or stutter somewhat. Did anyone figure this out yet?
Brad Miller
on Jan 3, 2011 at 3:53:49 pm
Unfortunately I have not, so I'm sticking with Adobe After Effects.
Brad Miller
on Oct 20, 2011 at 10:43:57 pm
Looks like Nobody ever has. I just tried it in Vegas 11, and same result.
Kaushal Shah
on Nov 11, 2015 at 2:07:45 pm
2015, using vegas studio 13, and still the same problem. Must be a way to fix this.
Aaron Star
on Nov 12, 2015 at 2:31:52 am
The videos are not embedded or are no longer posted. Hard to see what the issue is.
