What codec for .flv files?
COW Forums : VEGAS Pro
Rob James
on Jan 15, 2009 at 12:01:37 am
Hey guys, I'd like to drop .flv files on to my timeline, what codec do I need? I'm pretty sure .flv is a flash format file, though not certain. Is it as simple as installing Flash? If so, is there a downloadable version? It's for my offline PC, so I can't install it in the normal manner, by visiting their site, and doing the auto install. I'm using Vegas 7.0e, so anyone with experience loading .flv files into that version of Vegas, I'd love to have your input. Thanks!
Rob,
http://www.robjames.net/
John Rofrano
Re: What codec for .flv files?
on Jan 15, 2009 at 12:41:05 am
Vegas doesn't support the editing of FLV files so you will have to use an external program like Super(c) to convert them into a format that Vegas can edit.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Omer Aydin
on Jan 15, 2009 at 1:08:13 pm
You can open FLV files directly in Vegas by using a VFW (VideoForWindows) filter.
http://sourceforge.net/projects/ffdshow-tryout/
Install FFDSHOW and run "VFW configuration" (not "Video decoder configuration" which is for DirectShow decoding) from Start menu group, go to the Decoder tab, Codecs section, and make sure FLV1, VP6F are set to libavcodec.
(FLV files with H26x codec are not guaranteed.)
Luke Walker
on Nov 29, 2009 at 9:56:12 pm
I've followed the steps that you listed. Now what? I still can't edit .flv in Sony Vegas. What am I missing? Thanks.
Omer Aydin
on Dec 21, 2010 at 8:30:59 am
You are right. I just tried opening a flv with Vegas 6,7,8 and 9. It doesn't work with 7 and above. Only Vegas 6 opens it. Sorry for the mislead. I thought 7 was also able to open it with ffdshow.
Omer Aydin
on Dec 21, 2010 at 8:48:44 am
BTW, VLC Player can DirectStreamCopy a FLV file into a MP4 container without re-encoding. I tested it using a FLV file (h264) and Vegas 9 opened it.
russ hurley
on Sep 2, 2010 at 6:32:27 pm
just tried this - no dice with SVP 9.0 checked the codecs....SVP sat on the files for a while and looked like it was reading them, and then coughed up an error message - the same one i gt when i try to give it a MOV file...
Sony Vegas London Users Group
Rob James
on Dec 3, 2009 at 12:17:43 am
What I've found, since posting this question originally is it's best to convert your .flv to .avi using a converter program like Total Video Converter. http://www.freedownloadscenter.com/Multimedia_and_Graphics/Video_and_Animat...
Then it's simply a matter of loading the .avi file on to your timeline, and editing at will. Hope this helps?
Rob,
Rob,
Ben hen
on Dec 20, 2010 at 11:57:12 pm
I just used the Riva FLV Encoder, which is donor-ware and converts some standard file formats to FLV.
