Smooth move between key frames??
COW Forums : VEGAS Pro
Bruce Quayle
on Nov 20, 2019 at 1:47:37 pm
I am desperately trying to achieve a continuously smooth move using the Pan/Crop tool. However, each time I add a key frame to the timeline, it creates a pause at that point. I need to add key frames as the direction I must track on the graphic requires to be curved rather that straight. I have tried the various settings, but cannot get rid of the pause.
Can anyone suggest a workaround...or am I using the wrong tool?
Thank you in advance.
Cheers,
Bruce
Mike Kujbida
Re: Smooth move between key frames??
on Nov 20, 2019 at 1:57:39 pm
Vegas guru D. Eric Franks did a tutorial several years ago that I still find useful.
Bruce Quayle
on Nov 21, 2019 at 9:09:46 am
Thanks Mike. I'll check it out.
Cheers,
Bruce
