podcasts
VEG file is not opening on another PC
COW Forums : VEGAS Pro
Andrew Bak
on Aug 5, 2019 at 6:35:07 pm
Hi. I have 2 same (absolutely same) Vegas Pro 16 on 2 different devices (PC and notebook). When im working with the project on a PC - there is no any problems, but when I try to open the project on a notebook - there is a error - An error occured while loading the project file. And below - An error occurred reading the file. Make sure you have read access to the file/folder and that it is not corrupted.
The veg file with all the files for it is stored on a external hard disk. I tried to download all the files on a hard disk on a notebook but nothing changed.
Are there any variants tha tcould help me?
Francois Pénzes
Re: VEG file is not opening on another PC
on Aug 19, 2019 at 12:47:58 pm
Hi Andrew
You may want to try these 2 options.
1- When using an external drive, the path name changes. Could be Drive E: on your PC and become Drive H: on your notebook. Also look at the rest of the srting and make sure that everything matches.
2- Have a read at this older post. The pertinent stuff is at the end.
https://forums.creativecow.net/docs/forums/post.php?forumid=24&postid=90851...
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0
''When the cutting stops, the editing begins...''
