AVI no video in timeline - SVP13 64-bit
COW Forums : VEGAS Pro
Freddy Rodriguez
on Jul 13, 2018 at 3:26:11 am
I don't recall ever having issues playing back AVI files inside SVP13 (64-bit), but I have a client from UK who wants me to edit his 9-minute 650MB AVI file. Upon dragging it to the timeline, the audio waveform shows up just fine but the video track is all black. I have Vegasaur, so I used the Transcoder to convert the AVI to MP4, but after waiting 22 minutes through the rendering process, Vegas crashed. I started it up again. Crashed again.
I used VLC media player to convert, but it won't respect the original 30.000 fps. It kicks out some bizarre 21.### number. The profile I'm using has all the basic settings set to 'Same as source'. When this didn't work, I manually entered the '30.000 fps'.....same result.
I can play the video just fine on my Windows 7 64-bit through VLC player, but it's Vegas that doesn't wanna play with me ☹ HELP! Don't want to lose the client. Need money to eat food!
Graham Bernard
Re: AVI no video in timeline - SVP13 64-bit
on Jul 13, 2018 at 5:01:08 am
[Freddy Rodriguez] " Upon dragging it to the timeline,"
And have you set your Project Settings to Match the Media, through the Project Settings? Hmmm?
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 6:07:59 am
of course...automatically! I don't see how this would make the video show all black, even if I got the project settings wrong. Worst case, I'd see black bars around the video from getting the aspect ratio wrong, or maybe the frame rate wrong. This doesn't seem to be the case
Graham Bernard
on Jul 13, 2018 at 6:48:28 am
[Freddy Rodriguez] "of course...automatically!"
Well, I had to ask. I don’t take anything for granted.
Now do a MediaInfo on that AVI. Let’s see the results.
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 7:33:47 am
Graham Bernard
on Jul 13, 2018 at 7:41:48 am
[Freddy Rodriguez] "captre.jpg"
Freddy? What’s this for?
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 7:48:09 am
click it. you shall see.
Graham Bernard
on Jul 13, 2018 at 8:18:34 am
Hmm.. I can’t see all the data. It’s truncated. Did you use the Free MediaInfo utility?
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 8:25:19 am
is there particular data you're looking for in the AVI file, that will allow me to correct the issue with viewing the video within SVP13? hmmm?
Graham Bernard
on Jul 13, 2018 at 9:22:27 am
[Freddy Rodriguez] "is there particular data you're looking for in the AVI file, that will allow me to correct the issue with viewing the video within SVP13?"
Maybe? I wanted to see from MediaInfo what it is inside that AVI, as you know not all AVIs are created equally. Getting ALL the info may point us in the right direction.
Use the freebie MediaInfo s/w from here: https://mediaarea.net/en/MediaInfo
It has helped many of us on the COW to assist others.
Cheers,
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 10:09:26 am
Is there a specific type of AVI that you know off the top of your head that won't work with SVP13, and the solution for this?
Graham Bernard
on Jul 13, 2018 at 12:25:28 pm
[Freddy Rodriguez] "Is there a specific type of AVI "
An AVI is only the wrapper. It’s what’s inside that counts. If you use MediaInfo that will spring the DATA for us to see.
* Grazie
Mike Kujbida
on Jul 13, 2018 at 12:44:51 pm
Freddy, if you've never used MediaInfo here's a great guide.
https://www.vegascreativesoftware.info/us/forum/faq-how-to-post-mediainfo-a...
Freddy Rodriguez
on Jul 13, 2018 at 2:10:11 pm
Hey, Mike! Long time no see :-)
Freddy Rodriguez
on Jul 13, 2018 at 2:11:54 pm
Hey, Mike! Long time no see ☺
Format : AVI
Format/Info : Audio Video Interleave
File size : 646 MiB
Duration : 9 min 47 s
Overall bit rate : 9 216 kb/s
Director : Generplus
Original source form/Distributed by : Generplus
Recorded date : 2010-06-29
Copyright : Generplus
Video
Format : JPEG
Codec ID : MJPG
Bit rate : 8 323 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.134
Stream size : 583 MiB (90%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 9 min 44 s
Bit rate mode : Constant
Bit rate : 512 kb/s
Channel(s) : 1 channel
Sampling rate : 32.0 kHz
Bit depth : 16 bits
Stream size : 35.6 MiB (6%)
Alignment : Aligned on interleaves
Interleave, duration : 1006 ms (30.18 video frames)
General
Folder: C:\Users\CreativeCow\Desktop
Type: Video for Windows
Size: 661.02 MB (676,888,576 bytes)
Created: Thursday, July 12, 2018, 9:09:40 AM
Modified: Thursday, July 12, 2018, 9:14:04 AM
Accessed: Thursday, July 12, 2018, 9:09:40 AM
Attributes: Archive
Streams
Video: 00:09:47.567, 30.000 fps, 1920x1080x24, Blackmagic 8 bit MJPEG Codec
Audio: 00:09:44.000, 32,000 Hz, 16 Bit, Mono, Uncompressed
Summary
Album/source: Generplus
Artist: Generplus
Copyright: Generplus
Year: 2010-06-29
ACID information
ACID chunk: no
Stretch chunk: no
Stretch list: no
Stretch info2: no
Beat markers: no
Detected beats: no
Other metadata
Regions/markers: no
Command markers: no
Media manager
Media tags: no
Plug-In
Folder: C:\Program Files\Sony\Vegas Pro 13.0\FileIO Plug-Ins\aviplug
Format: Video for Windows
Version: Version 13.0 (Build 453) 64-bit
Company: Sony Creative Software Inc.
Graham Bernard
on Jul 13, 2018 at 2:22:41 pm
OK, I’ve not seen a Blackmagic 8 bit MJPEG Codec wrapped in an AVI. Maybe Vegas is having an issue with that. BTW, you don’t have the Video Track muted?
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 2:28:03 pm
I believe the footage is from a hidden camera of sorts, like a nanny-cam for spying on the nanny. The camera might have been the size of a golf ball. The video, when played back on VLC player, seems to be handheld but coming from inside a toy or something. If the footage says something about a BlackMagic camera, then I will guess it's one of those cube size cameras, like the GoPro.
Freddy Rodriguez
on Jul 13, 2018 at 2:39:35 pm
Graham, have you edited video before?
Graham Bernard
on Jul 13, 2018 at 2:50:34 pm
[Freddy Rodriguez] "Graham, have you edited video before?"
Once or twice. But over the short time I’ve been shooting and editing I keep my captured Media as simple as possible. Mike knows this 😉.
I’ve done some research on this BM CODEC for you. Very interesting thread for you to consider here on the Official Vegas Forum. It’s written by some of chaps that have helped me. This thread goes back 10years. https://www.vegascreativesoftware.info/us/forum/vegas-8-0b-and-blackmagic-i...
Cheers,
* Grazie
Freddy Rodriguez
on Jul 13, 2018 at 6:08:18 pm
I have a copy of Blackmagic's free software, DaVinci Resolve. It has the same issue: it ingests the footage but shows up blank in the preview window. Audio is fine.
Freddy Rodriguez
on Jul 13, 2018 at 6:17:25 pm
I'm calling it, guys. Time of death: midnight. I don't want to keep the client waiting. I'll let them know my software wasn't playing nice with their footage, and lose the sale. Looks like it's dumpster diving again this week for food 😢 (sad violin music)
I'd like to thank everyone who offered help. Graham, too!
